60ft times
Old Feb 22, 2008 | 12:00 PM
scites's Avatar
Default 60ft times
I am trying to lower my 60ft time. at the moment i am cutting 1.9's which is horrible. my comp engineering rear shocks are set at 50/50, my tunnel mount torque arm is set at -2 deg,i have lakewood non adjustable LCA and BMR relocation brackets set on lowest setting.
when i set my pinion angle i just measured it from were the TQ arm mounts to the rear. is there a better way to do it? im running in the mid 7.5s in the 8th @ 95mph with a 1.9 60ft
HHHEEELLLPPP!!!!!!!!!!!!!
Old Feb 22, 2008 | 03:02 PM
LT1_Fireman's Avatar
Thats how I measure the pinion angle however the best 60' I have cut 1.6 I had it set at -4deg with M/T d-radials at 18psi. Hope that helps.
Old Feb 22, 2008 | 03:17 PM
scites's Avatar
Ill try and set it a little lower around -3 or so and pull the front sway bar and see if that helps..i think if i can cut a 1.6 or lower i can get it down to about 7.0s in the 8th. then i can throw the bottle at her ***..lol
Old Feb 22, 2008 | 03:27 PM
djsanchez2's Avatar
What tire are you on?
Old Feb 22, 2008 | 03:51 PM
BMR Suspension's Avatar
LS1Tech Premium Sponsor
Active Streak: 30 Days
Active Streak: 60 Days
Hi Tom,
We have a video on our front page that does an excellent job of going explaining the process of setting pinion angle www.bmrfabrication.com How old are the rear shocks?
__________________
Allan Miller
President
BMR Suspension
www.bmrsuspension.com
(813) 986-9302
Old Feb 23, 2008 | 08:41 AM
Viper's Avatar
Nice video Lee!
Old Feb 23, 2008 | 02:36 PM
scites's Avatar
the shocks are not that old at all..i am running ET street 26/11.5/16
Old Feb 23, 2008 | 04:28 PM
The ET streets have avery soft sidewall that makes them difficult for a heavy vehicle. Your car would go faster on drag radial instead. The only thing you can do is try running higher tire pressure to stiffen them up or put a set of tubes in them.
__________________
Allan Miller
President
BMR Suspension
(813) 986-9302
Old Feb 23, 2008 | 09:08 PM
scites's Avatar
I have tubes in them now. I thru them in when i puttherim screws in..iv ran them any were from 18psi to 10 psi and im still not hooking
Old Mar 27, 2008 | 07:01 PM
scites's Avatar
any other things to look at?
