need help with spring choice!!!
Old Mar 11, 2008 | 06:07 PM
faktoryfreak02's Avatar
Default need help with spring choice!!!
which springs are the best buy or does anyone have springs for sale? looking for like a 2in drop and good launching springs. someone help me!!! thanks
Old Mar 11, 2008 | 06:23 PM
Black02SLPSS's Avatar
Are you wanting that much of a drop and have good weight transfer like what drag springs would give you?
Old Mar 11, 2008 | 06:32 PM
its a 02 z28, im looking for close to a 2in drop and a good drag launch spring, but i will compromise drop for a better spring if i have to. thanks
Old Mar 11, 2008 | 06:38 PM
SOMbitch's Avatar
Better get an order in to Sam Strano quick! But seriously, any lowering spring is not going to launch as good as a drag spring or even a stocker.
Old Mar 11, 2008 | 06:44 PM
alright well is there a good lowering spring out there? that anyone knows about?
Old Mar 11, 2008 | 06:49 PM
Strano's springs are the absolute best for our cars. Simply because they were designed around our cars. Sam Auto-x's his Z28 and he custom designed a set of lowering springs and sway bars for our cars. They drop your cars height about 1.0-1.2inches. However there are some people still cutting 1.5 60ft at the strip. But with any lowering spring your going to want to get away from stock shocks
Old Mar 11, 2008 | 07:31 PM
porksoda's Avatar
You can buy either the BMR or Strano springs and then trade me for my Prokit!
Old Mar 12, 2008 | 03:08 AM
1QUIKWS6's Avatar
Active Streak: 30 Days
Another vote for Strano first - BMR second as far as lowering springs go...
Don't forget that when adding lowering springs - you should also upgrade your shocks to be compatible with spring rates being used - otherwise your handling will be comprimised.
Best to talk with Sam on that issue...
