Stuck slider pins
I had the same problem. After fighting it for several hours I took it to a local shop paid 20 dollars and let them get it out. They did tell me they had to heat it up to remove the pin. when I got the bracket back I installed new pins and bolts and all is well.
![](https://ls1tech.com/forums/images/ranks/ls1tech20year.png)
It was hard for me to get it out...only had a heat gun. But I let it sit there with the heat on it for about 5 minutes and then yanked on it with a pair of pliers....it came out with some considerable force. The new one went in with no problem, though.
![Rolleyes](https://ls1tech.com/forums/images/smilies/LS1Tech/rolleyes.gif)
After some penetrating oil, heat three came out. The last one decided to snap. rigged the caliper to work for now. Anyone have the part number for the front caliper bracket? Do the sliders come with the new bracket? I am in Guam so I would have to order it from the mainland.
