K-members...worth The $$$$
Old 05-09-2008, 12:14 PM
Elliott's94Z's Avatar
Default K-members...worth The $$$$
So I have almost completed my suspension set up..and I'm looking at the UMI k-member. My only hold up is the price tag it comes with and it looks as if I should do the upper control arms at the same time. Are these worth it and can you tell the difference once on? The weight reduction is a plus..but damn that $$ tag
Old 05-09-2008, 12:58 PM
Wnts2Go10O's Avatar
youll lose a **** ton of weight on the front end and itll be a hell of a lot stiffer.
Old 05-09-2008, 01:15 PM
M-Ten's Avatar
Just go to the gym for a month
Old 05-09-2008, 02:04 PM
Looks as if with the lower A-Arms it sheds off 33lbs. Not bad.
Old 05-09-2008, 02:12 PM
M-Ten's Avatar
33lbs for the A-arms only? How much does the K-member save?
Old 05-09-2008, 04:01 PM
transam69230's Avatar
No it isn't 33lbs for just the A-arms, i think that is K-member alone. I did both at the same time, and we weighed the stock stuff and the aftermarket stuff, and i think it was like a 44lbs difference. I also took the front swaybar off too, and that was like 10lbs so about 50-60 lbs you can loose from a K-member and lower A-arms. I have the road race version of the UMI K-member, and the only reason i got it was cause my buddy sold it to me for $300 and it was only installed, and uninstalled he didn't even drive on it.
Old 05-09-2008, 04:10 PM
Chocolate Apocalypse's Avatar
Its 33-35.5 total for the K-member and upper and lower arms. Straight from the UMI site for the stage 2 kit which I have:
Description
This Stage 2 weight savings kit from UMI Performance includes the following:
(1) LS1 K-Member- #2320
(1) Tubular Lower A-Arm Set- #2300
(1) Tubular Non-Adjustable Upper A-Arm Set- #2311
Weight Savings- 33 lbs
Weight Savings with Chrome Moly A-Arms- 35.5 lbs
Old 05-09-2008, 04:34 PM
WITH the Arms not just the arms...k-member and arms = 33lbs off with UMI brand
Old 05-09-2008, 04:47 PM
barnat's Avatar
If intrested? I got a complete PA RACING front setup! K member ,upper & lower ADJUSTABLE control arms Let me know I bought it brand new and just found out it will not work with my APS TT kit
Quick Reply: K-members...worth The $$$$
