Cross drilled and slotted rotors!!!
![](https://ls1tech.com/forums/images/ranks/ls1tech20year.png)
ok here is my delima, i need new rotors like ASAP and i wanted to get the Bear eradispeed cross drilled and slotted but i called to order them and the darn things are on back order for 6-8 weeks so now i'm trying to find a new rotor to put on my car and i want a upgraded rotor thats a direct bolt on. do you guys know of any and where to get them thanks
![Burnout](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_burnout.gif)
The Tire Rack (www.tirerack.com) has Brembo OEM replacement front rotors in stock for $61 apiece.
THe Brembo OEM's work great. I run race pads and destroy rotors (aggressive pads chew stuff up), and they never warp and they stop great. I consider that an upgrade.
Slotted, etc. I consider that "pretty". If you need slotted, etc see what the other guys say.
E-mail this guy: LMoore9585@aol.com
They use Raybestos BruteStop rotors, and cryo-soak them. It was $356 for the rotors, cryo treatment, and shipping, usually about a week and a half or so to get them to you. The website is www.policerotors.com.
I haven't had any warpage problems since I've used them.
Wait for the Eratispeeds. Totally worth it. Got mine from Speed Inc, and had them do the install and a complete fluid purge.
Slotted and Cross drilled add NOTHING to performance. They are driveway jewelry.
![Driving](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_driving3.gif)
ok here is my delima, i need new rotors like ASAP and i wanted to get the Bear eradispeed cross drilled and slotted but i called to order them and the darn things are on back order for 6-8 weeks so now i'm trying to find a new rotor to put on my car and i want a upgraded rotor thats a direct bolt on . do you guys know of any and where to get them thanks
Just more of my ramblings....
It's personal preference and it's your car.....have fun!!!!!!!!!!!!!
![Cheers!!](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_cheers.gif)
Actually that isn't true...a thin layer of gas builds up between the pads and rotors when when the brakes are applied. With slots or cross-drilling the gas can escape bringing the pads back into direct contact with the rotors thereby reducing brake fade.
However, modern resins are so good, the outgassing problems have been all but eliminated (I can't think of a single pad that has a problem with this any longer). Many companies (Carbotech for one) cure the pads in an oven at extremely high temperatures to complete the bonding process (at temps over 1000 degrees).
So, 20 years ago, you would have been correct about the slots and holes. However, today they are a left over artifact of days gone by. Everyone remembers race cars running them and therefore, it must be a good idea (and, hey, they do look kinda cool). It is pretty much an appearance mod these days. This is why you can order Baer brake kits and Wilwood brake kits with solid (non drilled) rotors, the pads don't change, just the rotors. (Baer advised me that I'd get about 20% more life out of non drilled rotors when I ordered my last brake kit from them).
Anyway, this answer is too long already (sorry)....
Just my thoughts....
Kevin
