Sway Bar bushings
Old 09-28-2008, 06:15 PM
kraemer94's Avatar
Default Sway Bar bushings
I just purchase a set of Energy Suspension Sway bar Bushing for my 2001 Camaro SS from Sam. When I went to install them they are two small. Part number of the Bushing is 95162G. I have a stock sway bar on my car. Anyone ran into this issue?
Old 09-28-2008, 06:26 PM
wht01ws6ta's Avatar
I have Strano sway bars that came with the bushings and bolts and they fit fine but not sure of the part number.
Where are they too small, on the sway bar or on the bolt that goes through the middle of them?
Old 09-28-2008, 07:00 PM
kraemer94's Avatar
I have the stock sway bar. Here is a picture to compare the stock bushing with the new one.
Old 09-28-2008, 07:47 PM
wht01ws6ta's Avatar
Oh my bad I thought you were talking about the endlink bushings. That is strange especially since Sam's swaybars are thicker than the stock ones which would mean even bigger bushings would go on those.
Old 09-29-2008, 12:13 PM
LS1TECH Sponsor
Sam Strano's Avatar
He doesn't have my bars... he has stock bars. The car is an SS, stock bar on a SS in front is 32mm. The part number he has 9-5162 is indeed Energy Suspension's 32mm bushing/bracket kit (just confirmed that again in their catalog).
Either the bar isn't stock, or the car is not a base SS and has a upgraded suspension from SLP (like Ultra Suspension that used a 35mm front bar).
__________________
Old 09-29-2008, 03:34 PM
kraemer94's Avatar
Is there a way I can tell?
Old 09-29-2008, 04:10 PM
kraemer94's Avatar
Also Sam, Will the end links I purchase from you still work if the Bar is indeed a 35mm?
Old 09-29-2008, 06:07 PM
LS1TECH Sponsor
Sam Strano's Avatar
You need to just measure the bar. An adjustable wrench works nicely, then just measure the opening.
The links will work no matter what.
__________________
Old 09-30-2008, 03:02 AM
darknessxyz's Avatar
What size endlink spacer should be use with a lowered vehicle?
I read that when you use stock spacer with lowering spring, the swaybar "arm" will not parallet.
Old 09-30-2008, 10:56 AM
LS1TECH Sponsor
Sam Strano's Avatar
Nobody can answer that, because it would obviously depend on how low the car it. But in all reality, I don't care and don't change mine because there is no tangible difference, and if you run them too short the swaybar can hit the outer tie rod and bend it.
__________________
Old 10-01-2008, 01:41 AM
So for example, with your spring 1.2 inch drop, should I use an endlink spacer 1.2 inch shorter than stock? Or I can stick with the 3 inch stock endlink spacer?
I installed Vogtland spring (same drop) yesterday. When I put my swaybar back, the stock spacer look too long. The swaybar arm is at upward angle (about 45*). When that preloaded the swaybar?
Old 10-04-2008, 03:31 PM
kraemer94's Avatar
I went to the local autozone brought my old Bushing. The kit that I needed was 9-5165 got home and fits perfect.
Old 10-04-2008, 08:21 PM
ae13291's Avatar
i also em on vogtlands, a bit low of a drop but i was concerned bout the endlink spacer's as well. please let me know on that
Old 10-04-2008, 09:59 PM
LilJayV10's Avatar
What size bar did you end up having?
Old 10-05-2008, 09:08 AM
kraemer94's Avatar
32mm, But the kit 9.5162 did not fit. So either it was not package right or the Energy Suspension catalog was showing the wrong part number .
Old 10-05-2008, 11:37 AM
billyb's Avatar
well 1st you should measure the sway bar diameter then, order accordingly, works perfect every thing,
Old 10-05-2008, 12:23 PM
kraemer94's Avatar
Well I thought, I'm the first owner of my car and it was stock that I should have a 32mm bar so that's what I ordered. But the 9.5162 which states is for a 32mm bar does not work. So either it was package wrong or the Catalog is showing the wrong part number.
Quick Reply: Sway Bar bushings
