FS - Pavlock Ported Heads & Ti Exhaust
Complete set of Pavlock 241 Ported heads.
I purchased these recently ($450) from another member here (02txceta) and took them to get flowed and they were not quite what I expected. I don't have time to mess with this issue so I figured I'd sell them. I have $450 in the heads and $60 I paid to have them flowed.
OFF THE MARKET
Point Intake Exhaust
.200 118.7 107.2
.300 173.0 141.3
.400 214.3 168.7
.500 228.0 177.4
.600 239.1 182.1
Original Post:
https://ls1tech.com/forums/texas-cla...241-heads.html
Titanium Exhaust off an '01 C5 z06 with 60K miles. Was going to do bypass mod but.....out they go.
$260 Can install if needed.
On the Southeast side of Houston...prefer pickup.
J.R.
832.795.1750 Cell/text
OFF THE MARKET
.200 118.7 107.2
.300 173.0 141.3
.400 214.3 168.7
.500 228.0 177.4
.600 239.1 182.1
Original Post:
![Chug! Chug! Chug!](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_chug.gif)
J.R.
Closed ex-Sponsor Account
I read the original sell ad and I see that he spoke with someone here and was told what they flow. I am the only person that does cylinder head work in this shop and no one has talked to me. I stamp the heads either 510 1 or 510 2 (I do this to avoid this from happening) the only heads that dont get stamped are just heads that I do valve job and blend the valve job and short turn and the rest of the port is UNTOUCHED but flow numbers on those exceed 275 CFM.
![](http://i256.photobucket.com/albums/hh192/svtblacksnake04/510.jpg)
Im sorry to hear this happened to you and maybe I can help you out.
Now this gentleman owns the heads... Just because you did not personally do the port work on them does not mean they were not ported by Pavlock.
Different bench, different day, unknown correction factor I'm assuming?
I'm just going to throw this out there and say that the flow bench is really nothing more than a tuning tool the porter can use as he is developing the port/vj/chamber, etc...
I've had a set of heads that my porter was seeing 270-305cfm corrected from about .475-.600 on his flowdata bench. They made about 455/410rwhp SAE with a 231 deg /.585" lift cam and unported fast 90 in a 6-spd car (fairly decent street setup). While dynojets are probably more comparable than most, they are also just a tuning tool (though somewhat poor)...but the car ran VERY well.
Before I installed them, I had my machinist (not my cyl head porter) throw them on his smaller superflow bench just for grins and they went about 265cfm and backed up at .550" I didn't care because I knew they would work on the car and that was in no way a comparable test.
Goes to show when you are comparing different benches on different days with who knows what CF, you will always get different numbers. Furthermore, the flow numbers rarely really indicate the potential the head has to make the car move as they do not account for volume, airspeed, port and chamber design, etc all which contribute to the ability of the head to support power.
imma_stocker stated he made around 410ish with these heads on his LS1.
I installed the motor in the car before Jason bought it from Josh. I know for a fact Brian with Pavlock ported them
The heads I have are definately ported.!!
TTMFT.!!!
J.R.
![Bang Head](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_banghead.gif)
I hope this can clear things up a bit
-Matt-
Moderator
J.R., good luck on the sale.
Ok I cleared this up with Bryan. Bryan Pavlock did do the porting on these heads over a year ago. He ported them for his own personal car and then the heads got passed down and over this time im guessing the heads have went through all of these people. Now here is where I am comming from on this situation. I purchased a Flow bench and have been doing port work on LS series heads for a little over 6 months at Pavlock Performance. Bryan Pavlock is not a cylinder head porter nor does he do any of the head porting now. I just dont want this set of poor quality cylinder heads to reflect on the cylinder heads leaving the shop now. What I am offering 1stz06 is to let me look at these heads and see if I can correct the work. I will do the port work free of charge I just dont want these heads in their current state to continue going down the line. I know in hard times like this last thing a member wants is to spend their hard earned money on a product of poor quality![Bang Head](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_banghead.gif)
-Matt-
-Matt-
There are no hard feelings here just a bit more to the story than expected.
I'll get in contact with you sometime next week Matt and see if they are salvagable, if not....we'll set them on fire
![Devil](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_devil.gif)
I agree, there is a lot of variation between not just flowbenches, but operators as well. I've been over to Pavlock's and I noticed Matt uses a Flowcom, which is typically a ~$3000 option that a lot of people don't invest in. If you are not using a Flowcom, you would have to manually adjust to 28" at each lift point, take the percentages off of the manometer, and make calculations based off that to get the "corrected" flow numbers. I could see a big variation in that alone.
I would have to see the heads themselves since they have been hand-me-downed so many times it sounds like, but the story sounds to be accurate from what I hear. But they were heads I tinkered with for my own car. "Not what sales as our stage 1 or 2". I wouldn't bash the heads too bad like it sounds some of you are doing. My full weight street car went from 11.2x to 10.6x-7x's on 305 nittos with a Trex and those heads with a ported Fast 90 back than. Car made 420 with old head/cam set up, and dyno'd a little over 460 through a 12 bolt with the Trex/heads with an ls6 intake first. So regardless of numbers, the car hauled *** for a stock short block and full interior! If your going to "toss" the heads by all mean give them back lol..
I know these heads were before you start doing the head porting. Like stated above, don't judge Pavlock's work based on these heads. I've had Brian do work for me, he did a great job on the motor install!
LOL, I think the only one that really bashed your work was your own employee... LOL
![Grin](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_grin.gif)
