RCC Twin Turbo Build Update!!
#246
#248
regardless of whether they are factory or dynatechs, its not far-feched at all to use the stockers. They flow really well and hold heat and pressure really well, perfect for a turbo application. Most fbody guys with AC and a front mount turbo with a vertical radiator run one truck manifold and one off a C6 vette, and they've made 1xxx+ whp with em
#249
More updates/pics coming very soon.
#250
The motor was out to check for any problems and put a larger cam in. The black stuff you see is head gasket material. The block is a 6 bolt block, you cant see the 6th hole up top.The manifolds are factory ZO6 manifolds. They are perfect use because they are very light weight and flow like crazy.
#251
LMR is doing the final assemly on my car now. Im hoping to have a running car very soon. The build got put behind schedule due to some unforseen problems but its very close.
Heres some pics of the piping after the coating was done.
