header install
That's what I was thinking!! You can order that set up for under 500 bucks I believe? The no install charge on yourself! After that all you need is O2 extensions and call it a day! Then a tune if you want your check engine light off due to the front O2 not being hooked up.
Advice? Read the install guides and print out what you need as a reference. Plan for it to take longer than you expect. Dont get stressed out over it. Ask a friend for help? Stage 8 locking fasteners rule btw!
