I need a valvespring and harmonic balancer tool
Old 08-14-2011 | 06:32 PM
M6Z28's Avatar
Default I need a valvespring and harmonic balancer tool
Does anyone in Houston have an LS1 specific valvespring tool or a harmonic balancer installation tool that I can rent/borrow for a weekend? I'm about to install a cam in my Camaro and these are the only things I am missing.
Thanks,
Nick 281-794-5541
Old 08-14-2011 | 06:53 PM
drago1217's Avatar
Gl w/ install man. Call me after you get it installed. Or if you need some help
Old 08-14-2011 | 07:27 PM
91RS99z's Avatar
You can rent a valve spring tool from about any auto parts it ain't the most efficient tool but it got the job done, they will also rent a three jaw puller to get the balancer off...I had no luck finding a ls specific one
Old 08-14-2011 | 10:57 PM
06tx4.8's Avatar
12 Second Truck Club
text sent
Old 08-14-2011 | 10:58 PM
M6Z28's Avatar
I have heard too many bad things about the auto parts store spring compressors (like breaking bolts off in the head) and I have the puller I just need the installation tool for balancer.
Here is what I'm looking for:
http://www.jegs.com/i/Crane-Cams/271...ductId=1338385
http://www.byunspeed.com/product_inf...ducts_id=10976
Old 08-14-2011 | 11:12 PM
SS SLP2's Avatar
OP : maybe some of this will help
good luck, Johnny
INSTALL PULLY
I do not like to pull much on the inside threads of the crank I get two bolts with same thread as crank weld them head to head screw it tight into crank then slide a socket over then ( one that just go inside of pulley to align pulley) then use a big washer and nut on the free end of welded unit to pull pulley onto crank this way is easy on the inside threads of crank I also like to change the front seal while pulley is off
Home make a tool to hold crank to allow tighten pulley bolt, insert the tool into flywheel , remove round plug ( about 2-3 inch dia. ) on bottom of of flywheel cover to insert tool
make tool useing flat bar about 12-14 in long
1/4 x 2 x 14 ( notch in the side will allow the tool to hold itself in place by cetching on side of hole)
botton out pullet flush with end of crank with old bolt ,install new bolt torque to 37 lb then pull another 120 degrees if you do not have a compass to get the right degrees ( stop and think ) mark the bolt at 180 degrees and at 90 degrees then mark 1/2 between the two marks which i think will be about 135 degrees so you may go eather 140 degrees or 120 degrees from there ,
sorry do not think the picture of tool will show correct it should be about 2 in wide all way down
llllllllllll
llllllllllll
llllllllll<<
llllllllllll
llllllllllll
llllllllllll
llllllllllll
llllllllllll
llllllllllll
llllllllllll
llllllllllll
Old 08-15-2011 | 02:33 AM
CarsandWomen's Avatar
ive got an install tool, what part of town are you in?
Old 08-17-2011 | 10:01 AM
M6Z28's Avatar
I want to give a big thanks to 06tx4.8 and CarsandWomen. I now have all the tools for my cam install this weekend! You guys probably saved me $200.
Old 08-18-2011 | 01:52 AM
glad I could help! let us know how the install goes
Old 08-18-2011 | 08:26 AM
06tx4.8's Avatar
no problem bro
Old 08-23-2011 | 09:46 PM
M6Z28's Avatar
I just finished up the install. I have an appt. at G-Force 9am. on friday for a tune. I will return the tools asap.
