Clutch?
Old Dec 7, 2011 | 01:20 PM
CETA2002WS6's Avatar
Default Clutch?
Since my master cylinder is going out I think im just going to change the whole clutch out....what do ya think I should get?
Old Dec 7, 2011 | 01:26 PM
Morbid's Avatar
It would help to know what modifications are done to the car.
Old Dec 7, 2011 | 01:30 PM
My car is just stock nothings done to it till its paid off next yr
Old Dec 7, 2011 | 02:01 PM
westtexasbuff's Avatar
LS7 clutch kit.
Old Dec 7, 2011 | 02:02 PM
Bad Chad's Avatar
Originally Posted by westtexasbuff
LS7 clutch kit.
X2 on the LS7 clutch. Make sure use you buy an adjustable master.
Old Dec 7, 2011 | 02:33 PM
SSHAWK's Avatar
Call Jason at TDP he can help you.
Old Dec 7, 2011 | 02:44 PM
05 GSXR 1XXX's Avatar
X3 ls7 setup!
Old Dec 7, 2011 | 02:53 PM
Quick's Avatar
This
Old Dec 7, 2011 | 04:04 PM
TruBloodTransAm's Avatar
Stay away from Spec, heard bad things about them.
Old Dec 7, 2011 | 04:30 PM
slayer_taunu's Avatar
TDP stage 3.
or LS7 if you want to save money and dont plan on too much power mods.
Old Dec 7, 2011 | 04:39 PM
Cam72aro's Avatar
have you used them? Have you had a problem? You heard about problems. Well I heard that f bodies are peices of ****, I own one, lol. Unless you have personally used them then its all hearsay. I used several spec clutches and they make a great clutch. They have more clutches in use than any other company so they probably have more defective parts. Its a numbers thing. Jeremy at spec is very helpful and will work with you. I ran a 3 and a 3 plus and loved both of them. In your case OP ls7 will do more than what you will probably ever want at a great price.
Old Dec 7, 2011 | 04:43 PM
Brother has one on his f-body and it's a POS, driven it myself.
Old Dec 7, 2011 | 04:47 PM
Cam72aro's Avatar
What actually makes it a pos? How many miles? New flywheel upon install? Adjustable master? etc. If set up properly they are a really good clutch. My 3+ drove almost like stock and help a **** ton of power.
Old Dec 7, 2011 | 05:19 PM
HoustonSS's Avatar
Another vote for this. I'm still loving my LS7 clutch. After my experience, I'm doing okay without the adjustable master cylinder, but if we had it to do over again, I'd have put one in. If my stock one ever goes out, it will be upgraded to the adjustable. If you're like me and don't ever plan to do much to it, I think this would be a good way to go.
Old Dec 7, 2011 | 06:35 PM
BuckaroooZ28's Avatar
Monster ftw!
Old Dec 7, 2011 | 06:53 PM
diablo-Z's Avatar
Originally Posted by BuckaroooZ28
Monster ftw!
^^ yup
Old Dec 7, 2011 | 07:50 PM
Silver408z's Avatar
Its cool if you want to do a clutch but just because you are doing a master doesnt mean you need a clutch. You master is located out of the trans and you are adding extra labor and parts to your bill.
If you decide to do the clutch make sure you do a slave cylinder. The slave is inside and you have to remove the trans to change it. A slave it self is only like $125. Good preventive maintence item to replace.
Old Dec 7, 2011 | 08:06 PM
1_bad94Camaro's Avatar
LS7 clutch kit if your not looking to mod it to hard in the future. I'm running a Spec 3+ in my Camaro and I love it.
Old Dec 7, 2011 | 08:16 PM
sway99bird's Avatar
Jason at TDP !!!!!!!!!!
Old Dec 7, 2011 | 09:25 PM
khenry's Avatar
X2 on the slave & X2 on Monster
