Nitrous DYNO #'s: 113 degree shop temp pulled 496/513.
Old 08-20-2006, 08:16 PM
WizeAss's Avatar
Default Nitrous DYNO #'s: 113 degree shop temp pulled 496/513.
Well.... I was aching to get dyno'd before sprayin the **** out of the car at Ennis..... Went to get the bottle filled and USA in Pantego was doin dynos for cheap.
Hot as fud there............ car lost a few from the dyno at SQR. Put down 384 whp and 375 rwtq on motor. on the bottle it did 496 and 513 corrected. I think the heat may be to blame for me being under 500 lol
I am thinking that if i dyno in 70 degree temps i will pull 505/525 or so after i get tuned up.
on motor the A/F was 13:1 like a flatline in the ER!
On nitrous with the pills that are in it it did 10:1..... a little rich... I have two choices...... get a smaller fuel pill ....or get a larger nitrous pill .....
I am very pleased with the Speed Density tune from Daniel and Scott at SQR...... to get 13:1 like that in 113 degree heat is awesome! I need to see if I can get Scott to add one more degree of timing and also change the tune for the new thermostat i instaled. Do you think it is wise to change the A/F on motor to compensate for the rich condition on nitrous?
Old 08-20-2006, 09:34 PM
skipperbisket's Avatar
what shot was that? 100 or 125? the car seemed to fall off about 900' at the track
Old 08-20-2006, 10:04 PM
MAXIMO's Avatar
I didnt know USA had a dynojet
Old 08-20-2006, 10:26 PM
WizeAss's Avatar
125 zex which is rated at the motor. so basically it is a 110shot.... and you are right.... it runs good the 1st 8th mile... then slows a bit up top on the second.... I think a set of gears and ported heads are in order.
Old 08-21-2006, 12:50 AM
red90cobra's Avatar
no it's not wise to compensate for the rich condition on your na tune. just change the pills. either more nitrous or less fuel. what's ur mods?
Old 08-21-2006, 01:37 AM
daniel6718's Avatar
seemed to me to run better the second part...idk...i could see you in the rear view till 1000
Old 08-21-2006, 07:35 AM
BigBronco's Avatar
What were the SAE corrected numbers?
Old 08-21-2006, 08:34 AM
TINKRD's Avatar
i'm sure those were the corrected #'s.
If they were the corrected #'s, i dont know why he's talking about "113 degree shop temp"
i guess to make him self feel better that it made little power.
Old 08-21-2006, 02:28 PM
WizeAss's Avatar
hit the nitrous a little late.... cant beat a stalled cammed auto with a 1.9 NA 60ft!!!
just about caught your *** though!!!
Old 08-21-2006, 02:32 PM
WizeAss's Avatar
those were corrected.... and the power is right on for what is done..... you guys and your stupid i got 10 from my exhaust.... i got 8 bull ****.
t
and yes... the heat effects the incomming air temp on the motor... with a sd tune the car doesnt properly compensate for the heat...... so in cooler weather I should get a few more on the dyno. hense why it dynod better at SQR with no true duals and without the lightweight clutch/flywheel setup.
If i up the nitrous pill to go from 10:1 to 12:1...... lean it out a bit I gaurantee i can put down 525/535!!! I need to get a fuel pump..... atleast my nitrous setup aint blowin motors!! yet lol
Old 08-21-2006, 02:51 PM
A-Dub's Avatar
... with a sd tune the car doesnt properly compensate for the heat...... :
You sure about that one???
Old 08-21-2006, 03:12 PM
red90cobra's Avatar
i'm sure bout that
Old 08-21-2006, 03:38 PM
TINKRD's Avatar
t
grow some ***** and pill it up. stock bottom end can hold 550 to the wheels all day long.
Old 08-21-2006, 03:59 PM
TINKRD's Avatar
in cooler weather the computer wouldnt compensate as much on the dyno#'s. so it would still be around the same.
thats the whole point of SAE corrected #'s, you can dyno in 100degree weather or 60degree weather and the corrected #'s would be around the same.
Old 08-21-2006, 04:18 PM
monicaz28's Avatar
So what did your car run at the track?
Old 08-21-2006, 05:39 PM
daniel6718's Avatar
lol yeah you did, well have to line them up again when ive got some juice...its just an lt1...
Old 08-21-2006, 06:01 PM
WizeAss's Avatar
I RAN 11.7 at 120mph...... only 7.6 8th mile.
my best 8th was a 7.5 and best 1/4 mph was 121........ 60ft improved to a 1.8something now...... I think the best the car can likely do is a 11.5 or 11.6 in good weather with me driving...... need more mods to go faster. Like a 12 bolt, or heads, or pill it up a bit..... or all the above
Old 08-21-2006, 06:02 PM
WizeAss's Avatar
when ya get a bottle on that thing.... come run me from a 30/35 punch.... i will show ya what a 6 speed can do on the highway.....
Old 08-21-2006, 06:05 PM
WizeAss's Avatar
we are not talking about how the dyno works... I understand correction factors.... what I am saying is the car has more power at the temp it was tuned at........ 85ish.... a speed density car has no corrections in the engine for the air temp like a maf based car... it is tuned on a predetermined volumetric efficiency.... so yes... it will have more power in better temps. ya follow me here?
Old 08-21-2006, 06:12 PM
dubs6's Avatar
I cant wait for it to cool off. I trapped 119 friday spinning. Some tire and cooler air I might be able to finally hit mid 11's too.
