safest placement for jack stands?
oppinions wanted!
where is the safest place for jack stands if you are say.....installing headers?
i choose the frame rails rather than the A-arms
what do you guys think?
That's what she said...
I put mine under the bottom of where the a-arms connect to the k-member. See pic. If I need to jack the rear up, I put the jack stands under the axle tubes. If I need to unload the rear suspension, I put them under the body in front of the LCA's, near the SFC's.
http://i38.photobucket.com/albums/e1...nphonebook.jpg
PS - Phone book jack extension works like a champ.
![Winky](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_wink.gif)
Originally Posted by mitchntx
pic blocked at work ... so ...
But by your description, aren't you concerned about distorting that suspension pick up point?
dont do what he did in the pic
you wont distort anything, but you can **** up the bushing
If you try to put the jackstands under the k-member, they are too close together to get between them. They're also not as stable as they are farther apart.
I've been doing it this way for years, no problems with the bushings yet. 130k miles has probably done more damage to those dudes than the jackstands ever will.
![The Jester](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_jest.gif)
And likewise, I've been supporting the car on the frame rails near the factory jacking point for years without an issue.
to each his own, I guess.
I put mine the same way, multiple times with no problems yet
Originally Posted by Ceissus
Blur,
is that a 350EX four wheeler in the background?
![Sad](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_sad.gif)
http://i38.photobucket.com/albums/e1...1/dscf1178.jpg
Originally Posted by TheBlurLS1
back to cars~
what else can i use to plug my EGR ports rather than a freeze plug? autozone has no more freeze plugs, wtf!
