Tools & Fabrication Hand | Power | Hydraulic | Pneumatic | Welding | Painting
Driveway cleanup material
Old Jan 20, 2009 | 08:27 AM
jmd's Avatar
jmd
Exclamation Driveway cleanup material
I like using cat litter just fine for cleaning up ATF / gear oil / etc. on concrete. But it works so much better when ground to a fine powder. What is the best way to grind it up? Just an old blender? A corn mill? Is there something that's harbor-freight-able or able to be done in the kitchen when the wife is away?
Old Jan 20, 2009 | 10:25 AM
96blackta's Avatar
Get some masonry and concrete etcher by Behr from Home Depot. Use it full strength if you have to. That **** will strip off any foreign material from your driveway.
Old Jan 20, 2009 | 11:43 AM
jimmyblue's Avatar
Moderator
I've had decent results just brushing in some plain
laundry soap, let it sit for a while and hose it out.
Old Jan 20, 2009 | 12:44 PM
Lickeyman's Avatar
99.999999999% sure you can buy the material you speak of ready made.
http://en.wikipedia.org/wiki/Diatomaceous_earth
It's in your kitty litter and it's what Nascar uses ground up. I know you can get it somewhere but I can't remember where. And it's fairly cheap.
EDIT: found the ground up type for pools. Sure you can find it elsewhere or at a speed shop or something cheaper.
34 bucks for 50lbs
http://americasbestpoolsupply.com/p-...th-powder.aspx
Old Jan 20, 2009 | 01:56 PM
96blackta's Avatar
You might be talking about Damp Rid? Also sold at your local hardware store.
Old Jan 20, 2009 | 04:45 PM
budhayes3's Avatar
PT's Slowest Truck
Do a google search for "Speedy Dry", and you should find what you're looking for. It leaves a dusty mess but is good for big spills. It should be disposed of as hazardous waste, just like old oil.
Old Jan 20, 2009 | 08:19 PM
tillery's Avatar
Heard Tide powder works really good.
Old Jan 29, 2009 | 10:02 PM
johnson73801's Avatar
dry concrete powder works real well if your drive is porus.
Old Jan 30, 2009 | 02:59 AM
jcobra99's Avatar
Go with the cat litter method and if you have one power wash it up after the litter obsorbs the moisture.
Old Jan 30, 2009 | 03:05 AM
lemons12's Avatar
gasoline works better than anything..
seriously, it really does..
Old Jan 30, 2009 | 08:25 AM
STEEPSS's Avatar
haha. yes. it might be on the more expensive side of cleaning media though.
but right now, gas is on SALE!!!
Old Jan 30, 2009 | 08:54 AM
Old Geezer's Avatar
Burnout marks cover well!
I use a fine oil dry, that is reuseable, until totally saturated.
The racetrack stuff is likely finely ground rice hulls.
Kitty litter will not totally absorb the oil, and leaves a residue, that still has to be mopped up.
In extreme cases, use the entire cat!
Old Jan 30, 2009 | 02:48 PM
billyb's Avatar
yeah the big fluffy mother fuc----!!!! lol
Old Jan 30, 2009 | 04:45 PM
lemons12's Avatar
that is true.. but just one cup of gas will clean a big spot... dont have to use much at all...
usually if we have some sitting around and spill say 1/2 quart if oil... we will use a tad bit of gas to get it up... garage floor is spotless needless to say..
