Custom Exhaust Welding
What do I need to use when it comes to connecting. say, the Y-pipe to the cat, or the cat to the back end of the system. I've found these.
A ball flange. Not sure if this is over kill. I found these at Flowmaster, but they were kind of expensive.
Here was another kind of ball flange I was looking into.
Found these V Band clamps that look like they could be welded in and clamped together.
Or am I just completely over thinking this and all that needs to be done is weld one of these on each pipe and bolt them together?
To anyone with exhaust experience who would wish to give me some advise on this, it would be greatly appreciated.
Thanks!
read up on it a little or PM me or we will spend days in your thread on this...
All I do is SS, food grade processing plants are all SS tube
Do you have just a regular DC TIG machine that will crank out 60amps? If so you're
good to go
edit: You'll need more than 60 to do bracketry and what not but for doing that tube I wouldnt use more than 50 but
thats on a maxstar miller, might be different depending on your machine
I'm only doing pipes. It claims 30-125 amp, but I'm sure it's a very low duty cycle. Seems to do normal steel pipes fine. Last edited by Bonemaro2; Jan 8, 2010 at 09:09 PM.
I can give you BS internet welder advice but there are plenty of guys on here that do
exhaust with those lil 110 MIGs all day so listen to them and buy a damn TIG already lol
http://cgi.ebay.com/ebaymotors/WLK-3...Q5fAccessories
You can buy a tailpipe expander and make your own slip joints and use the lap style clamp like I linked. Or just butt the two pipes up to each other and use the butt style clamps. These things are super easy and I havent had one problem with leaks. I will never **** with flanges again.
for your 110v welder, i have used IIRC 308 or 309 wire on a 2 pound spool for my 110v mig without any problems. PM sent...
Gotta love the torch!
