Eastwood mig welders? any good?
has anyone tried the eastwood mig welders yet( http://www.eastwood.com/mig-welder-1...5a-output.html )? they sure do advertise the crap out of these things, but i don't know how good they are. any info will help. i need a reasonably priced weld for my 54 bel air project. thanks
i just found out that eastood is running sale this month in Hot Rod magazine... $319 for 135mig with welder cart and auto darkening helmet! it is very tempting but i would like to find someone that has bought one before i order one.
looks identical to my lincoln 140 same warranty too i think that its made by lincoln with eastwood stickers i got mine at lowes and it comes with everything but a good helmet and welding gas (i highly recommend getting gas if your doing body work) check it out here http://www.lowes.com/pd_256722-1703-...ductId=1072945 [/URL] compare with the eastwood and even if its not the same you need to think about the consumables of the welder tips, liners , nozzles, parts accessories if you go and get a welder from an online store than everything you get for it will have to come from the internet if you buy one locally at lowes sears tractor supply a welding store than you have those consumables readily available. oh yeah if you have trouble popping breakers all the time step up you breaker to a 30 amp that will keep you welding without having to run to the box to flip a breaker switch
eastwood says that replacement parts for there welders can be bought at any local welding supply store. they also say that their welder was designed and built in-house and is not made another company with their name on it. the eastwood has more heat settings than the lincoln.
well, i finally just said srew all this gambling on stuff that might (or might not) be worth it! i went up to welsco(local welding supply shop) and bought a brand new Miller Autoset 140mig! it comes with a 3 year warranty and i don't have to send it off to get warranty work done(if i ever need it), i just take it back up to welsco. also, comes with the peace of mind of knowing that i got a good quality!
Attempted to order one of these special combos from Eastwood. Spoke with David, was given a hard time, multiple times on hold and in the end I was told they were "sorry" but there was an extra $24 dollar charge if I wanted this this item. I said no thanks.
![Rolleyes](https://ls1tech.com/forums/images/smilies/LS1Tech/rolleyes.gif)
I purchased a mig from Eastwood, the worst purchase I have ever made. It is absoultely true that you get what you pay for. The cart and helmet arrived three days before the welder and guns. I put the cart together and the bolts hit the turning wheels and the wheels would not turn. The welder finally arrived and both of the clamps on the electrical cables were broke. I set the machine on the cart and the bolts on the cart hit the welder, and you can't open the door to access the wire without lifting the welder out of the cart. They sent me new power cables and the threads for the tip were onlt tapped halfway and the tip would not thread in. I returned the hole mess and was not refunded the shipping, which was about 90.00 dollars. The made in China tag pretty much says everything you need to know.
This thing welds much better than my old Handy Mig. The quality is good, I haven't hit the duty cycle yet and the variable amps versus the 4 position settings on the Lincoln are great. My Lincoln was an 86 amp machine. On the Eastwood, I have used the settings printed on the inside of the door and they are extremely accurate and I can produce very nice welds with it. I tought my Dad how to weld with it in about 20 minutes while he was visiting. He liked it so much that ordered one when he got home. It's not a Miller, but for $299 with free shipping with the gas regulator, it's a bargain. If I had it to do over again, I'd still order it.
the welder was probably temp out of stock, so we sent the in-stock items first.
Unfortunately if the bolts are installed incorrectly on the wheels this will happen. If you flip the bolts around it allows the wheels to turn correctly. I made this same mistake the other night when I was building a cart for my own Mig135. I will pass along that this is something they should cover with a insert or a picture with the cart.
Additionally, we are redesigning the carts, as I agree it can be a pain to tilt the welder to open the door to replace wire. But, if you tilt the unit up a little, the door flips open, and allows for access to the inside of the welder.
As I've mentioned on other forums, even the largest "U.S." made welding companies use Chinese internal components to build their welders. So that old blanket statement of "Chinese products are all sub-par junk" is kind of null and void in this day and age.
I'd be happy to help you try out another one if you wanted, but if not I really do apologize, and hope we can help you out on another product in the future!
-Matt/EW
