Quiet compresser
Also are there good ones that run off 110 that would be ideal a relatively quiet compresser that runs off 110. Mostly just for wrenching I'm not going to be building a paint booth or anything.
Thanks for any suggestions!
Bobby
A good indicator of "piston style" is a flywheel & pronounced cylinders- it looks like a 5hp lawnmower motor for a compressor. You should hear a very "bass" thump thump- when you turn the flywheel. Most diaphram units have a much smaller compressor and lack a flywheel. Ask the sales clerk if you can read the owners manual- or call the manufacturer- they should be able to tell you the exact style.
Expect to pay more for this type of compressor as well. But, they are also the more "professional" units, so it will last longer as well. (my friends is 34 years old)
The best thing to do is find one that operates at lower RPM. Many true "industrial grade" compressors run at 1750 motor RPM or even lower. That seriously cuts down on the noise. Of course, the only way to really know is to try it. I doubt you'll find many 110v compressors that are "quiet" though, at least not inexpensively.
Also, depending on the setup of your townhome, he may just be able to run a seperate service to the garage from your outside line directly to the garage. If your panel is full, that may be the only way to go about it.
Of cousre you will have to check with your local code first about doing so but a qualified electriction would know about that sort of thing as well.
http://www.sears.com/sr/javasr/produ...id=00919541000
Its pretty quiet too. When I am inside the house it kinda sounds like the dryer is on.
Not irritating at all.
Haha, that looks exactly like the Craftsman one I got at a garage sale for $75, except mine's ~25 years old (but runs perfectly), though mine is appliance avocado green in color, and that new one may have slightly better pressure ratings.
Don't forget to run an in-line filter on the output side to protect your air tools.
I changed the oil in the thing right after I bought it, and it's been running like a champ for 2-3 years now...
Yeah, the line filter thing is a great way to protect your air-tool investment.
