Tools & Fabrication Hand | Power | Hydraulic | Pneumatic | Welding | Painting
Yard remodel with new tool !
Old Oct 18, 2010 | 04:10 PM
davidws6's Avatar
Default Yard remodel with new tool !
Grabbed this used car lift and installed it under my car port.
So, here we go for some major surgery, and not to mention more $ $ $ $
Us boys n our toys .
Old Oct 18, 2010 | 06:32 PM
philsblwnz28's Avatar
So what I want to do, how thick is that concrete for the lift?
Old Oct 18, 2010 | 09:43 PM
davidws6's Avatar
Default Crete
Where the towers are, it's about 8 > 10 inches thick of 4000psi. Prolly a lil overkill but at least I know it won't go anywhere.
Specs from Mohawk say at least 4 1/2 inches of 4000 psi for a 10,000 cap lift.
Old Oct 18, 2010 | 09:48 PM
HavATampa's Avatar
Nice...not a big fan of the semi covered carport, but jealous of the lift. How fast was your heart beating on the first full lift of your car hoping it wouldn't topple over?
Old Oct 19, 2010 | 02:13 AM
67firebirdak's Avatar
Awesome! Thats a creative idea for a budget garage if i've ever seen one
Old Oct 19, 2010 | 02:14 AM
matthew20061's Avatar
Wow that's sweet, thought about building one in my back yard but then realized it would be way to cold in the winter....
Old Oct 19, 2010 | 05:43 AM
davidws6's Avatar
Default First time up !
I put my Silverado up in the air first, and YES, I was Nervous ! I figured I might as well go for it and put the heaviest thing I have on it .
Then re torqued the lag bolts and all seems good.
One good thing about the climate here, not too cold in the winter. However Summer is Hot n Humid like the tropics ! That's why I went with just a car port and not an enclosed building. + it's pretty shaded in the back yard so that will help.
Old Oct 21, 2010 | 10:39 AM
Ralls's Avatar
How much did you pay for that used lift? I'm trying to build a garage and put a lift in it. New 2-post lifts run about $1,400-1,600 so I'm curious if used ones sell pretty cheap.
Old Oct 26, 2010 | 06:55 AM
davidws6's Avatar
Craigslist > $1800 dropped off under the carport.
A new 2 post for 1400 > 1800, get what you pay for. But for a budget setup, to each is own.
This Mowhawk is about 5 K new, but it's built like a ton of bricks. + it has only 1 fluid line across the top. No cables or such from tower to tower.
In 07 I grabbed a used Nausbaum 2 post while I was up in Kansas. Got it for $ 1100 .
It worked ok but this Mowhawk has it beat hands down.
Keep an eye on craigslist, U never know .
Old Oct 31, 2010 | 12:36 AM
got milk??'s Avatar
Sweet, Get one of those 56inch fans from harbor freight for the summer. Won't do much for the humidity down here but it helps alot when working outside!!
