What kind of welder?
I would just look for a little 100 amp flux core wire feed welder, a small Lincon, Clark, or even Sears is fine. They're all pretty much the same internally anyway, and just rebranded. One thing I would suggest is you find one that can be upgraded to gas fairly inexpensively should you decide to do so.
Make sure you have plenty of ventilation, especially with Flux Core wire. The smoke is fairly toxic from the flux.
Just my 2 cents
Just my 2 cents
) http://store.weldingdepot.com/cgi/we...ot/WE6523.html
Oh, I noticed that ARC welders are cheaper, I'm assuming that means they are of lesser quality, but just in case, are they?
I was at my local Home Depot and saw a Lincoln 3200 for $430 ... a complete kit.
QUOTE]
That is why you use the large spool. The small spools cause the problem 9 times outa 10.
Mig IMHO is probably one of the easiest and efficiant ways to weld.(in all honestly mig is perfect for a beginning hobbyist) The only thing that i didnt like about that welder you posted was the fact that it has a small duty cycle (key value giving insight to a welders ability to be consistant during continuous use) I believe it was around 20 percent. Up that number and i think you will be much happier with your purchase/investment.
