Tools & Fabrication Hand | Power | Hydraulic | Pneumatic | Welding | Painting
Paint experets... Sprayed some summit hot rod black and it came out glossy not matte
Old 05-31-2012 | 06:00 PM
tylert14's Avatar
Default Paint experets... Sprayed some summit hot rod black and it came out glossy not matte
EDIT: Oops spelled experts wrong in the title! If an admin wants to fix it be my guest ha.
Any ideas? Summit hot rod black is supposed to be a low gloss acrylic urethane paint. Base, acrylic urethane activator, and urethane reducer if necessary.
I mixed 4:1 as instructed, and reduced with middle temp (dont have figures handy) urethane reducer. I literally added a "splash" of reducer as it was just a little thick for my 1.4 tip.
Temp was low 70s. Humidity probably in the 70% range.
Paint has cured for a day now. Feels hard to the touch, one problem though... It's about as glossy as it gets!!
Any ideas why this happened? I searched google and found no similar stories. Too high of humidity? Could the reducer have caused this?
Luckily I don't really care if these parts came out glossy, but this was my "test" for this paint and I'm disappointed as I have some items I would actually like to come out low gloss!
And lastly, does anyone have a non lacquer matte or semi matte single stage alternative?
Last edited by tylert14; 05-31-2012 at 06:02 PM. Reason: Ahhh fml spelled experts wrong in the title.
Old 05-31-2012 | 08:08 PM
slownova73's Avatar
its a possibility the reducer could have something to do with it. we spray a nice matte black at work, one day we had a few dry and look glossy, turns out we had a bad batch of paint from the manufacturer, so could be bad paint, wrong/bad/too much/too little reducer, a few factors could be the cause.
Try experimenting on something small, to test with, try different amounts of reducer, if you have enough to waste. my .02
Old 05-31-2012 | 09:07 PM
tylert14's Avatar
Yeah I think I'm just going spray some on a nice non humid day, unreduced, with a 2.0 tip. If that turns out glossy I'll be contacting summit for a replacement! I'm thinking this is just normal gloss black with a hot rod black label. When i say its glossy, I mean its GLOSSY. lol
Old 06-01-2012 | 10:56 AM
jmd's Avatar
jmd
do the instructions mention anything about adjustment via a flattening agent?
Old 06-01-2012 | 11:22 AM
slownova73's Avatar
I meant to say flatener instead of reducer. Did it come with a flatening agent? May e u should call summit and see ic ghey have some that will work with that paint.
Old 06-02-2012 | 10:20 PM
98camarols1's Avatar
try the sems hot rod black paint.easy to use and mix
Old 06-04-2012 | 09:49 AM
Old Geezer's Avatar
Wrong paint in the can, right label?? Summit shows both are available.
Old 06-06-2012 | 04:25 PM
1LOMARO's Avatar
I had the same issue when I painted mine Hot Rod Flatz Silver Sled Metallic... hood came out darker and had a gloss.... I finally figured out that I had not shook the can enough to get everything on the bottom mixed in correctly. Hope that helps.
