R134-A Manifold Guages
It looks like the best deal I can find is on CPS guages.. Anybody heard of them? Any comments on CPS?
For $60.00 they come with hoses, sight glass and valves on the hose leads.
Personally i've never heard of CPS, they are generic. I just purchased a new Robin Air 134A gauge set for $82 bucks. The only thing I dont' like about thoes CPS gauges is thoes shut off valves look totally dodgy and will leave a mess of dye around the connector and leak like a MF if not initially put on right. Robin air has the valve inside the connector.
It's not for a cam swap (right now).. I have an 89 Ranger that I need to retrofit and I need a set of guages to pull the system down to a vacuum to evacuate the system and remove the old mineral oil.
BTW - Section 609 addresses CFC12 which is Ozone depleting.. r134a is completely safe for the atmosphere.
Anybody else hear of CPS guages?
Its a common misconception that R134A is not harmfull, well not to the ozone layer. But HFCs are a greenhouse gas so its no better. http://www.cmdl.noaa.gov/noah/flask/hfc.html
HFC 134A is already given a date 2014 where it will be phased out like how R12 was.
I heard the R13 systems don't like overcharging. Does overcharging casue the compressor to shut down periodically?
Where on this Board do you post AC questions?
