Norco 86000
and Im not sure what you mean from out the back now that I think about it, I assumed you ment dropping the motor from under neath and lifting the car off it. something that will be an issue for you though is clearing the tranny out with that kind of design. there is a lot of bracing in the center of that left that will make it very difficult to work on things in the center of the car. If I were swapping clutches I would not use this lift, and it my hinder dropping a motor from the bottom as well depending on where it all sets under the car.
if you are set on a scissor lift I would look into a different type like maybe a tuxedo lift, or look for one that has the to lift tracks with no bracing between.
A 2 post will always be easier to work on the under side of the car with, but a lot of things can be done with a scissor style lift as well just not as easily
this is one im currently looking into cause I cant use the maxjax either. They make mid height versions of this design as well.
