Need Recommendations For Jack Stands
From a safety/durability standpoint, what would you guys recommend for a good set of jack stands?
Thanks
But I built these... 12" high and you jack the car up and place these under the wheels. So if you need to do brake work, they don't work. But any kind of engine or trans work, these work better as it's easier to get the car up that high and back down off of these. Jacks are little more dicey.
I received a set of Torin 3 ton jack stands from Amazon and they look like crapola and are heading back. Having jack stands that make me uncomfortable doesn't help since I have a small aversion to crawling under a vehicle unless it is on a lift
This is for a lowered car, if not lowered you will need another layer of wood somewhere.
