Welding observations from a novice
Took it home, unboxed it, got it setup and promptly went to work... melting gaping holes In my 3" down pipe. And anytime it wasn't burning holes (if I moved fast enough) , instead of a 'stack of dimes' it looked like a stack of BB's in melted candlewax.
I became well acquainted with my grinder and I could knock down the most visually offensive welding carnage. I started looking at Oxyacetylene setups and bought a setup with the normal torch, but swapped to a Cobra style last year. After that, my welds got a LOT better because I could control the heat.
Fast forward to last week. I'd seen a lot of reviews of the latest iteration of TIG welders from Harbor Freight. They've really stepped up their game on these. I decided to give it a try. I bought a HF Vulcan ProTig200 for $895.00 or so. Took it home and then wired a 220 circuit to my circuit breaker box to feed it. I've been setting up new twin turbo setup in my 5.3 turbo'd 96 Z28, using stock cast truck manifolds and some schedule 40 pipe and ELLs and was dying to try out the new TIG. After going to the local welding supply and getting a 100% Argon gas cylinder, I set it all up and started welding. Wow... this is easy! Very easy to get great penetration and visual appeal.
So, my recommendation for the guys considering a welder, don't be like me , buying a $99 low quality welder (it was a waste) nor the $1,000.00 I invested in the Oxy Acetylene. Just get a good quality (which nowadays, for the hobbyist like myself is under $1,000) TIG welder and start practicing. This welder comes with everything but a helmet, gloves and argon cylinder. Tig Torch, 3 different tungstens, 3 different Collette's, 3 different cups, Stick Welding torch, Tig Pedal, Argon Gauges, argon gas hose, Hookups for both 220v and 120v (that's right, you can run 120v OR 220v).
not for welding rusty things or iron
it was invented for welding steel that has been galvanized so you don't have to remove galvanizing
people misunderstand it's uses quite a bit and now the market makes these cheap garbage " gasless " welder for entry level
no gas = self shielding which is a completely garbage useless process imo and has no purpose or place what so ever building a car. 0.
shielded (w/ gas) is actually very nice to use its more for heavier structual things almost impossible to make it look bad it lays down very wet and flat but again little purpose for building a car except maybe if your building a 2x3 box frame and running lighter wire.
In general you get what you pay for with a welder its to bad their so damn expensive. An ideal setup for me would be a healthy sized (miller 251-252) CV wire machine for all my wire needs and then a healthy sized tig welder capable of atleast 3/16 - 1/4inch. But those together is like $8000+ for something im not going to be using on the daily and i'm not rich.
An xmt304 used can be had for 800$ and will most likely do everything you need it to do.
Oxy-fuel is underated and outdated, old school hot rodders would fab and weld roll cages with that, due to oxy-fuel being able to preheat, weld, and post heat the metal all at once.
Although it is very time consuming
There's a lot of choices out there. It depends on what you need to weld. If you need to weld aluminum or magnesium, then that's a whole other subject. And a lot more costly for a good machine
When people complain about a 110V fluxcore welder, they don't know how to weld with it. You can't fluxcore weld like you do MIG. You need to adjust the setup and process.
I have a Lincoln Weldpack 100 HD I bought for $150 3 years ago with Harbor Freight fluxcore wire and I have no problems. Sure, a $900 220V TIG will be a lot better, I should hope so...
I've been able to get the "roll of dimes" look out of mine...But IMO I'd rather the weld hold than look pretty. I've built multiple mufflers, a whole hears back exhaust for my old 04 GTO, tacked my current 95Z camaro exhaust together for final MIG welding and just this weekend welded 3/8" plate to the frame to make a new rear swaybar endlink bracket. Four different heat settings and I think eight different wire feed settings.
I'm no fancy well versed welder, but I have tinkered around with them enough to know when something is awry.
I love welding...I look forward to the day I have a detached garage with a 220V capabilities. Bring on the bigger fabrication equipment and MIG/TIG welder.
Not all pretty welds are strong, and not all strong welds are pretty.
Self shielding is straight garbage there is no two ways about it.
Gas shielding if you read my post could be used for a 2x3 frame, welding a boxed front cross member onto your frame besides that not much more. If you have a hard time making Gas shielded flux core look nice your doing something wrong. If you want to argue that self shielded fluxcore isnt garbage and has more purpose and is more suitable building a car I invite you to build your cage, hotside, coldside, fuel cell, tube chassis with it please post pics after you do so I look forward to seeing them.
Its not the flux core its the galvanize material that makes you sick. You could be welding it with stick or hardwire and still get sick its not the process its the material.
I was replying to a post that said flux core was invented for welding galvanized.
Any process that vaporizes it is an issue. I found that out when I was young with an oxy acetylene set up.
