How to get a Stripped Bolt out?
may still be your best bet. I bet the bolt /
stud extractor is too bulky to use up against
the pan wall. Get a set of 'Grips that have
serrated jaws (not smooth), put them onto
the bolt head nose-on for maximum bite,
with as hard a setting as you can just barely
snap closed, and cocked so you have a little
"free arc" to turn loosen. You can use an
open-end wrench to torque on the body if
hand torque does not suffice.
Though why an oil pan bolt should be rounded
is a mystery... may be it's driven in so hard
that the threads are trashed and the bolt is
bound up. Or, cousin Jethro used an English
thread bolt on the metric hole on account of
he lost one of the originals down the sump at
the Quikee-Loob.
I'd try twist sockets first... Everybody makes them... They work.
http://www.mactools.com/ProductDetai...?ItemNum=TS450
An engineer I know who specializes in metals tells me all bolts stretch and t-t-y bolts are a ploy by manufacturors to sell more bolts.....
2 - don't weld a socket onto it unless you want to compromise the integrity of the metal.
I'll give credit where its due, those ideas will work in other areas, but not for an oil drain pan. Try the vicegrips or the craftsman remover they mentioned. Otherwise you might want to consider getting a new drain pan. Since the threads are likely stripped anyway, you'll get a slow leak at the very best even with a new plug. Rubber plugs leak and don't seal properly, and there's really no way to tap that out. But i'm hoping your case won't be that bad and maybe it's just the bolt that is stripped.
If you wind up brining it to a mechanic, don't let them drill it out. You don't need metal shavings swirling around your engine, a new oil pan is pricey yes but a new engine is that much more.
I heard the oil drain plug is a torque-to-yield bolt....
I use an Impact Wrench on my drain plug. Works wonders!
In all seriousness the craftsman kit is pretty nice and may come in handy later.
Brad
- 6 Pt Socked Hammered On
- Craftsman Destripping Set
- Vise Grips
The Vise Grips were by far the best. I hated the destripping set. It destroys the bolt but doesn't turn it.
