Tools & Fabrication Hand | Power | Hydraulic | Pneumatic | Welding | Painting
WARNING: Sears floor jacks blow
Old Mar 7, 2007 | 01:59 PM
  #61
Chewy72SS's Avatar
Has anyone had any experience with the AL jacks available from Jeg's??
Old Mar 7, 2007 | 05:07 PM
  #62
Camaro_Zach's Avatar
I have a 2 year old aluminum one, zero issues. Didnt come low on oil, and I have left it with weight on it for well over 7 days way too many times.
Old Mar 7, 2007 | 11:14 PM
  #63
fuseone's Avatar
if i was you i would say that im just gonna sit here and tell people how bad the product is and tell them my story. im pretty sure they will change there mind because if it sends a few custmors away they will think that it would jsut be cheaper to give you you're way
Old Mar 8, 2007 | 05:55 AM
  #64
chpmnsws6's Avatar
Originally Posted by JustAnIlluzion
ive been rocking this for about a year
http://www.harborfreight.com/cpi/cta...temnumber=4172
Going on 3 years. My roomate took his Sears jack home and we all just use mine because everyone likes it better then the sears 3 1/2 ton jack. I've had it holding cars up for WEEKS without them dropping an inch. If it fails, its only 40 more to replace it
Old Mar 8, 2007 | 08:13 AM
  #65
BanditTA's Avatar
I've got a blackhawk jack we've had for 30 years, great jack needs paint but other than that its well worth the money.
Old Mar 8, 2007 | 08:25 AM
  #66
99blancoSS's Avatar
Had my Walmart jack for 3 years now and works as great as the day I bought it. 3 ton Blackjack I think is the name.
Anyway when you buy a floor jack just look at it first. IS it sturdy? Can you rock it back and forth while it's raised and see the struts and linkage have a lot of play in them? How is the construction? IS is rivited together or welded or bolted with cheap looking hardware? I paid $70 and have never had a complaint.
Common sense will go a long way here. My jack is not made of aluminum. Its steel and steel doesn wear out too often. Does what you buying look like a professional floor jack you'd find in a mechanics garage?
Old Mar 8, 2007 | 08:46 AM
  #67
SSmokin 01's Avatar
My Craftsman 3 1/2 steel jack broke as well. Would pump up until it made contact and then wouldn't go any further. Only used that jack maybe 20 times before it took a dump. I was a little disappointed to say the least .
I was right in the middle of taking my car off the jackstands when it happened. Went to Pep Boys and picked up a Torin steel suv jack. Worked great for around
10 times but then would pump up but not lock in place.
I was a little bent so I picked it up over my head and spiked it into the street . Just for the hell of it I checked to see if it worked. What do ya know, back in business . It's been good now for around a year without issue.
Still have the craftsman in the shed. I'm going to try the "fix" on it one day.
Old Mar 9, 2007 | 05:44 AM
  #68
eschoendorff's Avatar
No that's some funny ****!
Old Mar 10, 2007 | 03:21 PM
  #69
NassyVette's Avatar
My aluminum crapsman jack is so shity I've stopped using to lift my car. It makes creaking noises and loses pressure randomly. In my opinion its an un safe piece of **** that shouldn't be sold to the public. I feel sorry for the guy who loses his legs or his life under their POS jack! And isn't it fun telling the person who bought you the jack as a present that you never use it because its a big piece of ****!
Old Mar 19, 2007 | 08:25 AM
  #70
MustangEater82's Avatar
Mine crapped out as well I went with a harbour friegth aluminum one. The HF one is alot lighter too...
I still keep it around because it half works but sucks on lifting a car but was handy to have 2 jacks to position a fuel tank in a truck with.
Anyone have any tips on fixing it, I might give it a try.
Old Mar 19, 2007 | 10:54 AM
  #71
miamifan3413's Avatar
Originally Posted by phantomzer0
i used to work for sears. those aluminum jacks are pieces of ****. get one of the bigger iron ones. yeah, they are a **** load heavier but they do no break....ever.
I have the 3 1/2 ton steel jack from Craftsman that has taken a tremendous amount of use & has been great FWIW
Old Mar 20, 2007 | 11:59 PM
  #72
bursty's Avatar
Originally Posted by VETTEX2
my heavy duty metal ones are 25+ years old and work fine
+1 I'm using one that my dad got when he was just out of college. Still works like a champ with zero problems.
Old Mar 21, 2007 | 12:05 AM
  #73
ONEBADASSWS6's Avatar
I have both a Sears Steel jack as well as a US General Racing Jack.
The Sears is quick to go up to the surface you want to lift, but once you start lifting its slow as all hell.
The US General is very fast and very light, the only downside is that it requires a lot more effort to lift a car than the Sears does.
Old Mar 21, 2007 | 12:26 AM
  #74
2002/Black/SS's Avatar
i have a crappy "big red" pep boys jack, its big and bulky but it lifts like a bitch, real high. only problem is it falls when u twist the handle, not lowers, falls
Old Mar 21, 2007 | 10:46 AM
  #75
abustiffy's Avatar
Ive had one of the sears SUV jacks for about 6 years now. It has served me well. Been used and abused. On the contrary, we have 2 of those and one of the aluminum sears at the shop. 1 of each is low on fluid and not working. Just filled the aluminum about 8 monts ago, but in sears defense. it gets used a LOT.
If you want to fork out for a kick *** jack. Cornwell Blue Monster. One of the best jacks Ive owned.
Old Mar 22, 2007 | 01:17 PM
  #76
snkeh8tr's Avatar
4 + Years, no problems. Been through three cars, and this afternoon, Im gonna put it under the front crossmember of my 02 1500 ECSB Z71, and lift that big B**** up.
(after reading this,I'm gonna stand back)
Old Mar 22, 2007 | 02:20 PM
  #77
Eskimo's Avatar
Sorry to hear it.. I bought my 3.5 ton Craftsman "professional" jack in 1997, and though it's squeeked from day 1, it still works perfectly every time, and I use it often, which includes lifting the front of my 8000lb Dodge Cummins...
Old Mar 22, 2007 | 10:29 PM
  #78
blk97z28's Avatar
i got this one a day ago at menards for 48.16, it has a 4in saddle and it lifts 2 1/4 ton here is a couple pics
Old Mar 22, 2007 | 10:30 PM
  #79
blk97z28's Avatar
it weights 80.3 pounds and the handle can be put together like in the pics above to make it longer and they can be taken apart to make a shorter handle.
  #80
blk97z28's Avatar
