Air Compressor break-in and air tool assembly
My Ingersoll-Rand compressor had already been pre-run at the factory - there was a small amount of water in the tank, and there was evidence of oil in the pump (but the pump was empty). So I assumed they already "broke it in". But if that's what they call for, I'd follow their instructions.
And I use teflon paste (Loctite's white pipe thread sealant). Mostly because I love the smell of the stuff.
How I would do it:
On the outlet of the compressor, put a butterfly valve (it's either open or closed)
Mount the water separator and regulator on the wall (preferably)
Use a piece of flexible tubing to hook the outlet of the butterfly valve to the inlet of the water separator, and then the water sep feeds in to the regulator
The outlet of the regulator is where you're going to hook up your tools.
The idea behind putting some distance between the compressor and the water separator is that it gives the air some time to cool down. The shorter the run, the less it can cool, but if you can possibly cool the air down some, the water separator will work better.
Here's a thread I made when I plumbed my shop. I'd never done anything like it before, but I am *extremely* happy with the results. I went from a small roll around Campbell-Hausfeld compressor to this setup, and can't be happier.
https://ls1tech.com/forums/tools-fabrication/480039-plumbing-shop-air.html
I'd try putting it together as tight as you feel comfortable with... and fire that thing up! All it can do is leak on you.
Smoke check!
(as long as you have oil in the pump, you can turn it on with no worries about hurting anything)
