Tools & Fabrication Hand | Power | Hydraulic | Pneumatic | Welding | Painting
Workbench question
Old Sep 17, 2007 | 04:13 PM
Dip Stick's Avatar
Default Workbench question
After looking alot online I am thinking I might just end up getting the connectors from Lowes and makes my own out of 2x4 etc.
Just wondering what size workbenches you guys use for say transmission rebuilds and such. Space is a little limited in the garage, especially depth wise. Im thinking I may have room for 20" at the most but hoping to hear 16" will work just fine
Length wise I have room for up to 72" bench. Was thinking of doing a 4 shelf, one foot spacing between each shelf, bench. Using 2x16x72 or 2x16x60 and then using 4x4 or such for the legs. Shrugs I havent really sat down and designed one yet, as I am hoping someone knows of a good place to geta reasonably priced one
Thanks for the help
Old Sep 17, 2007 | 05:28 PM
Specialized's Avatar
Mine is 32" Deep, **72" long**edit, stainless cap. I love it. Got a nice big vise on it. I'd like to say I can pretty much work on anything on it without a ounce of trouble.
Old Sep 17, 2007 | 05:30 PM
I got mine out of a machine shop that was closing down. I literally got it for free. Its even got two cabinets underneath with 6 drawers each.
Old Sep 17, 2007 | 08:57 PM
Camaroholic's Avatar
16" would be too shallow to do much on, IMO. I'd say 24" deep minimum.
My other $.02, make it as heavy as possible. 2x4's would still be pretty light, unless you stick a heavy top on it. I like heavy workbenches, they don't move around or rattle on you when you "work" on them.
My work table came from a used surplus furniture place, was a work table at the old Levi's factory in Amarillo.
Old Sep 17, 2007 | 10:19 PM
Shock Hawk's Avatar
I would suggest a surface other than wood. I have a sheet of tin or galvanized steel over my plywood so that wood dust and stuff don't stick to parts. No matter what you think, you can't get plywood clean. You could shoot a thick layer of some kind of glazing agent over it. That'd work too.
Old Sep 18, 2007 | 07:28 AM
cnorton's Avatar
Just a few observations based on experience.
Make it as big as you can. You'll always need more room than you have.
The surface should be as hard as possible. Steel plate is good. Plywood is not. Professional transmission builders use steel tables with drain channels and catch basins since there is so much fluid trapped inside a unit that runs out, even after the pan is drained.
Don't squeeze your shelves too close together. If you space the shelves at 12", you'll find that just about anything you want to store will be 13" high.
Best advice: Look for a used unit from a shop going out of business. You'll be much happier in the long run.
Old Sep 18, 2007 | 11:33 AM
boondiggys's Avatar
i thought 40" tall was going to be big...After using it for a while, the thought never crossed my mind.
Old Sep 25, 2007 | 07:32 PM
SSJIMMY's Avatar
you have to sit down and really think what your using it for my dad Builds cabinets and his main table is about 5x8 and the thing is crazy solid. its very nice to have a big heavy duty table but make sure your able to move it to if your ever going to want to. I know for my dads we actually have to jack up and put dollies under it to move it. so you may want to think about some heavy duty casters or wheels if you want to move it. I would say for what you want though make it as close to 24" as you can.
Old Oct 3, 2007 | 09:26 AM
WE TODD DID's Avatar
I'll post some pics tonight of mine that I have at the house. It is 96" long, and 24" wide. The top is 3/4" plywood with 14awg steel on top. I had a metal shop put a bend on the front edge, and the sides. I also have a backsplash with a trough in the back. I made the top where it has a tilt to the rear so fluids will drain into the trough, and it is also concaved in the middle so fluids will be directed toward the middle and then run into the back. I have about $200 invested in the metal, and probably $50 or so in the wood and materials. It is attached to the wall, and built with 2x4s and is very sturdy! I would say that 24" would be the minimum width that you would want a bench. The front edge is also about 40" from the floor if I remember right. I'll measure tonight.
Old Oct 4, 2007 | 04:17 PM
67rsss's Avatar
We have two benches, both wood. The little bench is one of the 2x4 type made with one of the kits from home depot. 6 foot long. The other is one we got from an old toy maker. It is 10 foot long, has two heights for misc parts, and is awesome. It is based on 2x12 boards, weighs a billion pounds. Go as long as you can, and oil the surface real good before you use it. If you have enough length, you can add some steel plate to a 4 foot section to give you the best of both worlds...
Old Oct 4, 2007 | 04:38 PM
jimmyblue's Avatar
Moderator
Kits are for wussies.
My main workbench is 16' long and 30" deep. I made it out of 500+
running feet worth of PT wood fence that I tore down when I moved
in here. Cut the pointy end off the pickets and butcher-blocked
them, glue and nail on top of 2x4" rails (back, center and face) with
4"x4" legs (ends and center). The legs were fence posts and the
rails were fence stringers. It's massive and can take some hard
bonkin'. I left one section open and set a radial arm saw down in it.
Got drill press, bench grinders, lathe, joiner and a bunch of junk
sitting on it. A big bench means you don't have to straighten up
as often Plus you can really grief on whatever's in the vise.
I had fence wood left over so I made a littler one for the welding
stuff. Covered that one with fire brick from when I busted out the
fireplaces.
