Tools & Fabrication Hand | Power | Hydraulic | Pneumatic | Welding | Painting
engine removal plate
Old Dec 15, 2007 | 07:44 PM
ROLLN's Avatar
Default engine removal plate
i remember one of our sponsors sells a plate that bolts in the valley for pulling the motor from the top, anyone remeber which sponsor it was.
Old Dec 16, 2007 | 06:18 PM
redbandit98's Avatar
there are probably a few that sell them, but im almost certain summit racing sells them. I just bolt a chain to opposite sides of the heads and do it like that. Ive pulled and installed 3 engines that way.
Old Dec 16, 2007 | 06:31 PM
UBLUZIN03's Avatar
That would be blownchevy..
Old Dec 16, 2007 | 06:38 PM
ROLLN's Avatar
thanks guys!
Old Dec 16, 2007 | 07:54 PM
fuseone's Avatar
how well does this work and is there any risk in damging the aluminan blocks by using it?
Old Dec 19, 2007 | 05:32 AM
Superman09's Avatar
LS1Tech Sponsor
QTP also makes one....
__________________
Featuring 6 different turbo kits for your F-body!
Check us out on Facebook at: www.facebook.com/HuronSpeed
Old Dec 19, 2007 | 07:26 AM
mitchntx's Avatar
I built one by using 2 lengths of angle iron, welded back-to-back, holes drilled to align with the valley cover bolts and then multiple holes along the top to feed a shackle through.
It's not pretty, but it's cheap and it works.
Old Jan 6, 2008 | 11:29 AM
Firehawk441's Avatar
I use the QTP plate.
Old Jan 18, 2008 | 03:23 PM
formulakid1's Avatar
I bought an Engine Tilter from Harbor Freight and welded four tabs on it.
Just remove the knock sensor plate and bolt the tilter down and you are in buisness.
I'll try to get some pics up in a day or two.
