mig welder troubles
if it's not something like voltage/amperage being way off, or a liner, it's probably your board. i guess it could be really contaminated gas too
The problem ended up getting worse. I can crank the voltage all the way up along with the wire speed and it won't even burn a hole in exhaust tube.
Does a shop need to test the circuit board? Or is that something one can do with stuff at home?
I am going to try and get the circuit board tested at a shop on monday, unless there is a way to test it at home. Do you know of a way? Is it simply just a continuity test from one side of the board to the other? Sometimes I think maybe its the wire feeder, but a bad feeder shouldn't cause my weld to go crazy.
i agree ,there are alotta things that could cause this.
one of my new guys had this problem and he didnt have the machine grounded correctly ( duh ) and ended up getting fired a week later for some other **** ( everyone says there a welder these days)...
http://s5.photobucket.com/albums/y18...t=MVI_0199.flv
here is a picture of the "weld" produced by the video
voltage tap 4, wire above 70
No pool or wire mound was formed; just a bunch of smoke, black and brown colorings on the metal, and a whole lot of nothing
I could also maybe see some contamination from poor surface prep but that isn't the root cause of this problem.
