Tools & Fabrication Hand | Power | Hydraulic | Pneumatic | Welding | Painting
extended rear studs remove lugnuts
Old May 6, 2008 | 08:41 PM
noregretz999's Avatar
Default extended rear studs remove lugnuts
I have extended wheel studs on my 9 inch. A shop put the wheels on, and now that I go to take them off I have not been able to find a socket that will reach the actual bolt because the studs are too long
The rim design doesn't allow the stock jack handle thing to work either. WTF are you guys doing to get these off
thanks andrew
Old May 6, 2008 | 10:02 PM
RoDan's Avatar
deep socket?
Old May 6, 2008 | 10:08 PM
tried it just a little short
Old May 6, 2008 | 11:38 PM
496chevy's Avatar
thanks andrew
fail!
Old May 7, 2008 | 12:23 AM
RoDan's Avatar
well, they obviously used something to put the lug nuts on, so there has to be a socket deep enough! lol
Old May 7, 2008 | 08:46 AM
mrdragster1970's Avatar
6 & 8 Second Club
Impact sockets. Mine are a little longer than my deep Craftsmen.
Old May 9, 2008 | 08:05 AM
MustangEater82's Avatar
try putting the deep socke on with no wrench, and see if the lug sticks through the middle a little. You can sometimes get the wrench on slightly to get the lugs off...
or a deeper socket.
Old May 9, 2008 | 03:34 PM
lgobraves's Avatar
crawfoot?
Old May 9, 2008 | 04:51 PM
BlueZ35th's Avatar
could always torch it off, blue wrench it. im gunna go w/ the deep impact socket. found at sears, mayb even lowes cobalt brand.
Old May 9, 2008 | 09:32 PM
CTSmechanic's Avatar
I'd have them shortned up..... Lathe...cut off wheel... whatever...
Old May 9, 2008 | 11:42 PM
Jim98WS6's Avatar
Yeah, you should cut them off. Any longer than all the way through the nut is not helping. Just make sure you cut them off with the nuts on then the nuts will clean up the threads.
