99 Formula Ram Air/Forged 346/New Paint/Built M6/Nitrous
Year: 1999
Make: Pontiac
Model: Firebird
Price: $9500
Mileage: 136000
Private or Dealer Listing: Private Listing
Location (State): NY
Color: Gray
Transmission: Manual
Drivetrain: Rear Wheel Drive
LS Engine?: Car has LS engine
Up for sale is my 1999 Pontiac Firebird Formula. The car has 136,xxx miles on it and is originally from Georgia. It’s a 6-speed car with T-Tops , Charcoal Leather interior, power windows, locks and the AC has been removed. I bought the car as a project this past February and have put countless hours and money to get it to where it is today. It pains me to have to sell the car but sometimes life gets in the way. I have less than 1000 miles on the car since I’ve owned it.
Paint:
The car was prepped and painted by Kolorcraft Autobody and Marine here in Syracuse, NY. It was previously painted black. The color is a 2003 ford color-Dark Shadow Grey Metallic with a lighter black tint. It also has darker grey shadowing in the hood vents, fog light areas and vents on the side(See PICS) The Superhawk hood alone had 8 hours of prep before it was painted as it was still in gel coat when purchased. All of the door jams and hatch sills were painted and cleared as well. The engine bay was painted flat black to match the underside of the hood. It has not been washed since it was painted and has been quick detailed after each time it’s been driven.
Motor-
About three months ago, the oil pump failed and I ended up spinning a main bearing. The motor came out and was completely redone at TBR Machine. It currently has about 500 miles on it since the rebuild and runs great. It was street tuned by a local guy with HP Tuners. It makes great power all the way through the power band. I had it on a local dyno that reads about 35-40 rwhp high and it made 459/382 on motor and on a 150 shot with 4 degrees taken out it did 620/609.
-Aluminum Block with all brand new Federal Mogul cam, main and rod bearings. Using Brad Penn 10w-30 Oil since Rebuild.
-Tick’s Polluter Cam- (24x/24x (.61x"/.61x") 112LSA
-Scat Forged H-Beam Rods with ARP Bolts-
-Mahle Pro-Pack Forged Pistons with new Mahle Rings
-Low Mileage Ls6 Crank-(Rods, pistons and crank were all re balanced during rebuild)
-Ported and Polished 241 heads with 2.02/194 Valves, Patriot Gold .650 springs and brand new ARP head bolt kit. New GM MLS Head Gaskets.
-New Milidon HV Oil Pump with new GM O-Ring -60 PSI oil Pressure.
-Comp 7.400 Hardened Pushrods
-Ls6 Intake with a BBK 80mm TB
-MSD Wires with new NGK TR6 plugs
-40 lb Injectors-
-255 intank Pump
-SLP Lid with K&N Filter
-New Oil Pressure Sensor
-New Oil Pan, Waterpump, intake, rear cover, Rear Main and Valve Cover gaskets
Transmission-
-Tick Performance Built Stage 2 -T56
-Ram VDS Adjustable Clutch with Billet Flywheel
-Pro 5.0 Shifter with Hurst Pistol Grip Handle
-Z06 Slave with Drill Mod
-New Prothane Tranny Mount
-New Tranny Mount Bolts
Suspension and Rear End
BMR Adjustable Torque arm
BMR Adjustable Panhard Rod
BMR Lower Control Arms
BMR Weld In Sub frame Connectors
Eibach Pro Kit Springs with Bilstien’s on all corners
10 Bolt rear with Brand new 4.10 gears (Installed at Motor Rebuild
Front Sway Bar has been removed but will be given to buyer
Exhaust
SLP Long tube headers
TSP True Duals with Dynomax Bullet Mufflers and Turndowns before rear axle
Brakes
Baer Eradispeed Slotted/drilled zinc plated rotors
[Stainless steel brake lines
Wheels
Weld Prostars 15”x8” Rears and 15”x3.5” Fronts. . They will come with all lugs and spacers.
Power Adder-Used on Dyno and one Street pass.
Nitrous Outlet 78mm TB Nitrous plate
NOS Pro-Shot Nitrous and Fuel Solenoids
Edlebrock Purge kit
All lines under the hood, main feed and brackets included but no bottle.
Stereo
Alpine CD/MP3 player with Pioneer speakers
Misc-Purchased and Installed 2/10
Replaced both Window Motors
Harlan Shift Light in Pillar
Brand new High Pressure and Low Pressure Power Steering Lines
New Napa Battery
New Alternator
Fixed Headlight Grind (Flipped Gear)
Newer Clean Carpet Installed
Updated from Post 24
-I also replaced the tailights with very low mileage lights that are in perfect condition.
-Replaced both Rear Hatch Shocks and that works perfect now.
-Replaced the upper center console with a gray unit with a decent ashtray lid. The nitrous switches have been relocated to underneither and now has the cubby hole.
-Replaced the plugs with new NGK-Br7EF's
-Did black overlays on the FORMULA and front bird on the car.
Issues-
-The car still does have a very small leak at the rear plate/oil pan.
-The rear end is whining on accel at 30+ speeds. It was very quiet when it was done but after a few thrashing passes, it got loud. That will need some attention. I've put close to 1000 miles in it's current state and it should be fine.
The car is located in Syracuse NY. I’m looking for 9,500. Thanks.
Pics and Vids Below:
Videos
Motor Dyno
http://www.youtube.com/watch?v=26X1H...eature=related
Nitrous Dyno 150 pills
http://www.youtube.com/watch?v=SdiZn...eature=related
Motor Pass In Car
http://www.youtube.com/watch?v=e3g_LhrCv7Q
Nitrous Pass In Car- On slicks. Was driving the hell out of it.
http://www.youtube.com/watch?v=6cPkp_lixWs
Motor Dyno
Motor Pass In Car
I almost bought this car when the previous owner was selling it, wish I woulda know you were gonna do this I woulda waited and not bought my car. How do you like it?? What were the dyno numbers?
http://www.youtube.com/watch?v=fi4b6Q3w1WE
