Western Members CA, AZ, NV, UT, CO, NM, HI
what to do to get more hp
Old Apr 11, 2010 | 12:37 PM
jayayule's Avatar
Default what to do to get more hp
stock lq9
i know heads,cam,intake and headers. but which ones? cnc ls6 heads or l92. and then the cam. would like to max hp,but still be streetable
Old Apr 11, 2010 | 01:26 PM
djsanchez2's Avatar
Talk to Patrick G about a custom spec'd cam.
AFR 215 (milled for min. of 11:1 compression)
Fast 92mm
American Racing headers
4" Mufflex system or 3" Duals
150 TNT F2 kit w/ Nano
The real question is do you want to keep the stock bottom end or do you want to open it up for forged/stroked parts?
If you do i would consider a 408 build and jump up to
11-11.5:1 compression
CNC L92 heads
102mm intake (possibly ported)
ARH big primary headers
custom cam like before
Old Apr 11, 2010 | 02:10 PM
masterz28's Avatar
Are you on a budget?
Old Apr 11, 2010 | 02:59 PM
jayayule's Avatar
budget no but dont want to put crazy money in
Old Apr 12, 2010 | 03:51 PM
ss.slp.ls1's Avatar
I know a guy who will ship you a set of like new LS3 heads w/ rockers and intake manifold with fuel rail and injectors for 1075 shipped.
That paired with a custom cam will yeild ~470rwhp.
Old Apr 12, 2010 | 06:02 PM
jayayule's Avatar
so are the ls3 heads better then the l92 for power
Old Apr 12, 2010 | 06:06 PM
ss.slp.ls1's Avatar
They are identical except for the fact that LS3 heads have hollow intake valves which are lighter than the L92 solid intake valves.
Old Apr 12, 2010 | 06:24 PM
djsanchez2's Avatar
The only thing with the L92 heads on a stock LQ9 is the huge valves limit cam size, and the pistons need to be flycut for anything serious. (assuming you keep the stock bottom end)
Old Apr 12, 2010 | 06:55 PM
jayayule's Avatar
so ls3 sound like the way to go . so to get real hp with the ls3. flycuting must be done
Old Apr 12, 2010 | 07:00 PM
ss.slp.ls1's Avatar
I imagine with a mild NA cam, that won't be necessary. I would get a cam custom ground for your set up, then measure the PTV clearance with the cam installed. Having to fly cut is not the end of the world.
Old Apr 12, 2010 | 07:03 PM
ss.slp.ls1's Avatar
This is the cam I was going to go with before I changed my direction to FI:
223/231 .610/.617 113LSA +4 advance using Comp LSL lobes
Here is the link to a thread by Pat G detailing the results with that cam (dynograph is posted):
https://ls1tech.com/forums/dynamomet...p-446rwtq.html
Great looking power curve! You could vary the cam a little to pick up some more top end power while giving up a little low end torque.
Old Apr 12, 2010 | 08:18 PM
djsanchez2's Avatar
Damn those are good numbers. I would have milled them, ported the MAF/intake, went to a 100mm lid, and used LT's with 3" catted Y-pipe and a 4" mufflex system. That would put you EASILY in the upper 400's. (~475-485)
I wanna see someone break 500hp with one of these combos. Damn that got me drooling over building the 6.0 i have laying in the garage. Imagine all the people you would **** off with such a basic low dollar build.
Old Apr 12, 2010 | 09:00 PM
jayayule's Avatar
thank you all for the in put . im just new in the ls world. the more input the better
Old Apr 12, 2010 | 09:05 PM
SUCK MY SS's Avatar
just get an intake tornado and be done with it
Old Apr 12, 2010 | 10:24 PM
jayayule's Avatar
is that what you did
Old Apr 12, 2010 | 11:05 PM
SUCK MY SS's Avatar
i got the vornado... its a combination of vortex and tornado
Old Apr 13, 2010 | 02:00 AM
Empatho's Avatar
U have nothing on me homie, I got like 3 tornados and an electric supercharger taped up and stuffed in the intake, top that homie you don't want to see me creep up on you with my 24" yo
Old Apr 13, 2010 | 12:02 PM
Ryne @ CMS's Avatar
LS1TECH Sponsor
ls3 heads milled .030", 224-234 114+3 cam, good quality long tube (AR,kooks,qtp,edelbrock victors) i have done this combo quite a few times it is a proven performer
Old Apr 13, 2010 | 04:29 PM
jayayule's Avatar
thanks going to start to price out the parts.
Old Apr 13, 2010 | 04:53 PM
ss.slp.ls1's Avatar
LS3/L92 heads w/ rockers - ~$500-$600
LS3 intake manifold w/ ruel rail and injectors - ~$300-$400
90mm TB - ~$390 (Holley 90mm TB)
Valvesprings - ~$275-$300 (PRC or Patriot dual spring kit)
Pushrods - ~$90-$100
Cam - ~$400
Headers - ~$700 (used SS AR or Kooks 1 7/8" headers)
Heads/Cam gasket kit - ~$245-$280
LS2 Timing Chain - ~$40
Ported Oil Pump - ~$150
Tune - ~$500
That is a nice rough estimate for you...
