Fs: 99 SS low miles in az
Selling my 1999 Camaro SS. The car is just under 19,700 miles and runs great. Its pewter with redfire cloth interior and an automatic. The car was org from ny but is now located in Az(shipping the car was around 800). The car has never seen rain or snow and the underbody was coated before being delievered. Car sits under a cover and get zainoed every week with z coats of z5 and 2 coats of z2. The car has going 12.91@106.6 in one of its couple times 3 times to the track in its life. The da of the pass was 3624. The car was dyno tuned by nicd and in 113 degree heat after being driven an hour to the place it pulled 317/335 sae. The car has a lot more in it with a tune for 93 and not being driven that far to get tuned. The car doesnt have to much timing in it right now. The car does throw a o2 sensor heater code which is an issue with certain long tubes, and the o2 sensors being as far down stream as they are. I verified that the o2 sensors are giving out the correct voltage and they are. Also since i put the ported t/b in the idle is a little higher then it should be (around 800rpms). Finally the car needs the motor mounts replaced. I have prothane motor and tranny mounts sitting in my room and was quoted 300 for an install but have not had time to make it to the shop.
Mods on the car are:
Exterior Modifications:
-OE concept black ZR1 rims with nitto drag radials
-Zaino wax
Performance:
-Tpis long tubes
-Custom true duals with xpipe and magnaflow mufflers
-Coolant bypass
-MTI Lid
-Slp ram air
-K&N Filter
-Hypertech 160 thermostat
-Slp smooth Bellows
-Custom tune
Suspension/Chassis:
-Eibach Prokit
-Monroe sensatrac struts
-UMI Relocation Brackets(not installed)
-BMR chromoly LCA
-Prothane Motor Mounts(not installed)
-Prothane Tranny Mount(not installed)
Drivetrain:
-Protorque 3000 stall
-TopGear Motorsports custom shift kit with .490 boost valve
-B&M 24K Tranny Cooler
The car was well maintained and have all recipts and documents on the car to included all work done, org window sticker, brouchours, parts recipts etc
Price is : $15,995. Car is located at Luke Air Force Base in Phoenix, Az
-Zaino wax
Performance:
-Tpis long tubes
-Coolant bypass
-MTI Lid
-Slp ram air
-K&N Filter
-Slp smooth Bellows
-Custom tune
Suspension/Chassis:
-Eibach Prokit
-BMR chromoly LCA
Drivetrain:
to make a long story short I told him what the reserve was he offered less then he bidded and said he would be willing to fly out and pick it up the next week. I said i'd think about it and get back to him in the morning and he responded back no tell me know i didnt and never heard back from the guy
wow a chevy to a chicken stang? stay with the camaro! But if you get the stang good luck! Every highscholl kid has one! the camaro is unique and you don't see 500 of them a day!
