2001 Red Trans Am Firehawk - $13K A Good Deal?
Hello all. I came across a 2001 TA Firehawk for sale with 54K on the odometer. I can probably get it for around $13K - is it a good deal? I have not yet seen the car (other than pictures) or driven it yet. I understand the car was well taken cared of.
SLP Firehawk 17" chrome wheels
SLP Bilstein ultra performance suspension system w/re calibr Bilstein shocks
SLP Auburn high torque performance differential
SLP Revised Front End links & 1LE Panhard Bar
SLP 35mm Frt swaybar & 21mm rear swaybar
SLP High performance stall converter (2400-2600 stall)
SLP 3.73 ratio gear set
SLP Subframe connectors (bolt on/welded)
SLP Strut tower brace
SLP Tuned/Long tube headers & y-pipe
SLP header installation kit
SLP high flow catylitic converters
SLP TCS reversal module
SLP speed processor for 3.73 gear set
SLP high flow air box lid
SLP cold air induction kit
SLP MAF (85mm)
SLP 160 deg. low temp thermostat
SLP air temp module
Lakewood traction bars
Lakewood adjustable panhard bar
OEM replacement calipers (painted to match car)
Bear EradiSpeed+ slotted & cross drilled Zinc washed rotors (front & rear), Hawk high performance brake pads
Hypertech Power Programmer III
Traction Control
Custom Headrests w/Firehawk Emblem
Ebony Leather Seats
All original parts that were replaced by SLP parts are included. Any and all documentation also included. There is a scratch on the passenger door which doesn't look too bad from the picture I saw. Tires are about 70% good. Thanks for your feedback.
SLP MAF (85mm)
SLP air temp module
Traction Control
Ebony Leather Seats
