Centerline Convo Pros on my 25th Trans Am 'vert...
Here is my TA with Centerline Convo Pro wheels, 15x7.5 in back with a 5" offset, and 15x4 in front with a 1.75" offset. 275/50/15 Nitto 555R's and 165R/15's.
![](http://www.ayresweb.com/Convo_Pros/convo1.jpg)
![](http://www.ayresweb.com/Convo_Pros/convo7.jpg)
![](http://www.ayresweb.com/Convo_Pros/convo5.jpg)
Had to have my little helper hold the lug nuts while I put the wheels on. She's gonna be daddy's little car nut.
![](http://www.ayresweb.com/Convo_Pros/convo_d.jpg)
Time to go test the tires out now![Driving](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_driving3.gif)
Shawn
Shawn
do u have to do and mods to make them fit or they are bolt on wheels .,,am thinking to get the same set up fot 2000 TA
i like ur pimp wheels
![Nod](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_nod.gif)
do u have to do and mods to make them fit or they are bolt on wheels .,,am thinking to get the same set up fot 2000 TA...
-Shawn
I like the look of the wheels, but would not want the skiny on the front for daily use. Would the 15x8 with 5" backspacing work on the front and not stick out?
Could I convince you to put the rear on the front and take a pic?![Grin](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_grin.gif)
Hmmm... I like the look of the 15" wheels but 15x4 is too small of a width for the street. Could I use a 15x6? Or will that still get in the way of the calipers. Most 15x6 seem to only come in a 3.5" offset. Would this work?
![Icon Confused](https://ls1tech.com/forums/images/smilies2/icon_confused.gif)
Hmmm... I like the look of the 15" wheels but 15x4 is too small of a width for the street....
-Shawn
LS1Tech Co-Founder
I daily-drove my Formula with Weld Draglites (15x3.5s front, 15x8s rear) for over a year. It was my only vehicle at the time, and I didn't have any problems with it. If you drive on the streets like a "normal" car and not try to haul *** like a madman on the corners, they will be fine. You will also learn not to tailgate cars, as those skinny front tires aren't very good when you have to slam on the brakes. ABS gets a real workout ![Winky](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_wink.gif)
Tony
Tony
ta25th do i live in benton AR
i live in little rock and i think i seen ur car before
-Shawn
-Shawn
also we do some street racing every weekend in little rock u are more than weelcome to come up there
Do you happen to know the weight of the fronts, with and without tires. If you have these numbers it would be much appreciated. Randy
