Safely removing overspray on chrome wheels
![Unhappy](https://ls1tech.com/forums/images/icons/icon9.gif)
As the title says, I got some slight overspray on my chrome wheels. I called the company that had them chromed out but the guy over the phone wasn't even that sure
I did do a search and a member ended up using acetone w/steel wool but that sounds like it would scratch the surface or dull the finish. Don't want to make a costly mistake. Please help. Thx
![Icon Confused](https://ls1tech.com/forums/images/smilies2/icon_confused.gif)
thanks for all the suggestions guys, I guess I'll give steel wool a try and be careful with it. What about acetone? Would that be safe to use as a lubricant with the wool?
NO!!! Steel wool is an abrasive...an extremely fine abrasive, but an abrasive nontheless! Using it will leave very fine scratches in the plating. You may not see them very easily, but they will be there, and possibly allow the plating to break down over time.
Use acetone, lacquer thinner, enamel reducer, or as a couple of others suggested, a clay bar. Using a solvent will dissolve the paint, rather than "scraping" it off.
I've been using 0000 steel wool to clean chrome and glass for 30 years and haven't had any scratching problems. Chrome plating is harder than steel so I don't see how it will scratch. If scratches show up it means they were there already and the steel wool cleaned out the scratches and made them visible.
No, if you didn't have scratches in the first place, it means you didn't have scratches in the first place. If you have scratches after it means you just put them there.
