What's the biggest Tire that will fit a 15x4" rim?
1 Post
Just like the title says? I got some 15x4 summit stars for the front and 15x8 with E/T Drags for the back. I need tres for the front.
1 Post
I'm Talking about a REAGULAR radial I can get from any tire store. Im Not trying to spend $150 per tire. For Mikey thompsons. Just want the biggest tire I can fir on a 4 inch wheel
I ran this tire on my Convo Pros for a while. If you are ever going to go over 110 mph, I would suggest a real tire designed for it.
http://www.tirerack.com/tires/Compar...=1&RunFlat=All
Hey s0n, Your old Z is trapping 114 on motor. 12.1 spinning some wore out et streets.
1 Post
Kumhos it is! Plus I heard the ride and handle better than the M/T's. there are a couple of 10 second bugs around here, I bet they run VW tires on the front lol
i just got the summit stars too, 15x4 and 15x10. i use the 165/80-15 KUHMO Powerstars. i have before on the my old 15x3.5 Prostars. My question to you did you use a spacer on the front wheel being that they use acorn lug nuts for did you grind the calipers.
