Last edit by: IB Advertising
See related guides and technical advice from our community experts:
Browse all: Chevrolet Camaro or Pontiac Firebird Tire Repair and Maintenance
- Camaro and Firebird: Tires General Information and Specs
Step by step instructions for do-it-yourself repairs.
Wheels & Tires: Everything you should need to know is in here. A Must Read!!!!!!!
#522
Originally Posted by FUroundeye
I'm pretty sure I know the answer to this, but just double-checking: an 18x9.5 wheel w/ a 65mm offset wouldn't fit on the front w/out a spacer, right? TIA
#523
Originally Posted by F-117HWK
I dont know if this has been answered, so let me know if it has and where to find it but I have a '99 T/A with the stock 16" wheels and 245 rubber and am looking to purchase the Torq Thrust II's 17x9 for the front and 17x11 for the back with plans to put 275's on the front and 315's out back...what fit modifications will need to be done to ensure no rubbing/hitting problems? Any info will be greatly appreciated, Thanks.
Also I read that tire height differences will disable ABS on f-body's...Will the proposed setup make this happen? (Im planning on using the Eagle F1 DS-G3's)
#524
Originally Posted by monkeysl
looking at purchasing some black z06 motorsports wheels. 18x10.5 in the rear, is it possible to fit a 315 or will i have to go with a 295? and what offset is recommended
#525
#528
C6 replica's
18x10.5's +56 out back 7.94" backspacing
18x9.5's +56 for the front 7.45" backspacing
I don't mind using the BFH
Does the backspacing matter since we know the offset?
This is all hypothetical since i don't have an f body again, yet.
Wheels confuse me.
Wheels confuse me.
#529
Originally Posted by BlueSix
C6 replica's
Wheels confuse me.
Wheels confuse me.
Offset is the distance front the center line of the wheel to the backside of the lug mounting plate.
Backspace is the distance from the back surface of the wheel to the backside of the lug mounting plate.
The only unknown factor to calculate one from the other is the thickness of the rear mounting bead.
Yes wheels get confusing, that is why we are here to try to help.
#531
So would the wheels i listen fit?
#532
Originally Posted by Xsta Z 28
Sorry: yes. The fronts will be just fine, I used to run that offset. The Backs, may nned a little bit of BFH, not much. I used to run a 58 mm offset in that size out back.
I know there is a "range", but I prefer to be dead on if possible.
Thanks!
#533
Originally Posted by TP121
OK, so if I want the wheels flush with the outer fender lip front and rear on a 1.5" drop, what spacing do I need for 18X9.5/275 and 18X10.5/285 rims and tires?
Thanks!
Thanks!
Mine are both 38 mm offset.
18" x 9.5" with a 275/35ZR18 front, 18" x 10.5" with a 295/35ZR18 rear.
More pics here: http://s16.photobucket.com/albums/b28/shudbdrwg/Fikses/
#534
Looks real good- Any problem with the ABS with the different size F/R tires? I know its minimal, but there is a difference of what, about 1/4 inch?- just curious if you have encountered any problems?
#535
#536
Does anyone run 275/40-18s on their Camaro? I was on Goodyear's website, comparing GSD3 OD and widths. I noticed that my 245/50-16 have an OD of 25.7 inches, but 275/35-18s have an OD of 25.5 ??? THe 275/40-18 GSD#s have an OD of 25.7 inches. THat would lead me to believe that the 275/40-18 are a better (more comfortable) ride that the 35 series? not to mention that I was running a 3.42 gear with the 16 tires, but my new Moser 12 bolt has 3.73 gears, so I dont know what the RPM differences will be.
#538
You have a bit of missinformation:
A 275/40ZR18 is 26.8" in overall diameter.
Still the 275/35-18 (25.6) has a smaller diameter than the 245/50-16 (25.7)? I mean its only .1 inch but that still surprised me. So a 275/40-18 (26.8) should be able to fit ok, right? My car is not dropped at all. I wanted to get wider wheels in the back, so I could use 295/35-18 (26.1) but I'm not sure how more more contact area I will get by doing so.
Also, If I went 295's in the back and 275 up front, are teh differences in OD enough to cause problems with the ABS? I've heard different diameter tires can cause false ABS inop errors.
#540
I am running the 275/35ZR18 on 9.5" wide wheels front and 295/35ZR18 on 10.5" wide wheel out back.
