Old 04-26-2016, 02:01 PM
How-Tos on this Topic
Last edit by: IB Advertising
See related guides and technical advice from our community experts:
Browse all: Chevrolet Camaro or Pontiac Firebird Tire Repair and Maintenance
Print Wikipost
Wheels & Tires: Everything you should need to know is in here. A Must Read!!!!!!!
Old 06-20-2006, 10:35 PM
  #541
turbols1_05's Avatar
Just got my Crager SS rims 18x9 +36mm offset (6.61"BS).Car is not lowered,what tire size would you recommend??
turbols1_05 is offline
Old 06-21-2006, 01:41 PM
  #542
Xsta Z 28's Avatar
Originally Posted by ROCNDAV
I like how the 38 mm offset fits in your fenders. What backspacing do those wheels have?
Thanks. I do not know the BS, I usually only quote wheels by the offset. No need to know both, since they are related.
Xsta Z 28 is offline
Old 06-21-2006, 01:42 PM
  #543
Xsta Z 28's Avatar
275/35ZR18 will be perfect. Same OD as a stock tire.
Old 06-24-2006, 08:08 PM
  #544
Switchblade's Avatar
This thread has a lot of good information regarding wheels and tires.
I'm currently planning to upgrade my tire/wheel combo on my 02 Z28. The car currently runs the 16x8 factory chrome wheels with 245/50/ZR16 tires. I'm looking at a set of Black C5 Z06 Wheels with 54mm Offset equipped with Goodyear Eagle F1 GS-D3 tires - 275/40/17. On paper this should work, but would like a final opinion before I pull the trigger on this upgrade.
Thanks
Switchblade is offline
Old 06-25-2006, 11:29 PM
  #545
ArcticZ28's Avatar
I'm sure this has already been answered in this thread but I can't search through 15 pages right now...
I'm gonna be going with tomz's z06 motorsport 18x9.5 and 18x10.5 setup. I know I should go 275's in the front but what profile - 30, 35, or 40? Also, what are my options for the rear. I don't want to pay out the *** for 315's so I was considering 305's or even 295's. What are my options for those, considering my top two tires I would want would be GS-D3's or KDW2's. Thanks in advance.
ArcticZ28 is offline
Old 06-26-2006, 07:57 AM
  #546
Xsta Z 28's Avatar
Thanks
That will be fine.
Old 06-26-2006, 07:58 AM
  #547
Xsta Z 28's Avatar
275/35ZR18 front and 295/35ZR18 rear. GS D3's do not come in those sizes, but the KDW2's do.
Old 06-26-2006, 05:29 PM
  #548
Smile
Originally Posted by Xsta Z 28
That will be fine.
Thanks
Old 06-26-2006, 10:11 PM
  #549
cookba's Avatar
ok well i have the same stockers 16x8 snowflakes running 245/50/16. i also want the C6 ZO6 (Tomzwheels) but in an 18x9.5 with 275/40/18 KDW. will i have any problems with the odometer/speedometer, and if so how do i fix it? THANKS
cookba is offline
Old 06-27-2006, 08:32 AM
  #550
Xsta Z 28's Avatar
Post
Tires you quote are 1" taller than stock overall diameter. So you need to reprogram your speedo.
A 275/35ZR18 will be the same overall diameter as stock.
Old 06-27-2006, 08:45 AM
  #551
cookba's Avatar
ok thanks for the help. but how do i reprogram the speedo. can the tire shop do that? sorry for the dumb question.
cookba is offline
Old 06-27-2006, 07:13 PM
  #552
Xsta Z 28's Avatar
With a hand held tuner such as Hypertech, Diablo. Or thoguht a Speed Shop with LS1 Edit. No the tire shop cannot do that.
Old 06-28-2006, 03:05 PM
  #553
I <3 80057's Avatar
Thumbs up
That's normal. That wheel fits almost identical to OEM SS wheels.
May buy some 18x9.5 Z06's all the way around, has a +57mm offset. The chart shows +56mm as the max, is +57mm ok? Will I have to be cautious on bumps, etc.? My car is already lowered and the stockers have no problems whatsoever. Thanks!
Blake
I <3 80057 is offline
Old 06-28-2006, 04:36 PM
  #554
Xsta Z 28's Avatar
Blake
57 is OK. The larger the number get the more the wheel moves inwards, so those will have a somewhat tucked in look. Honestly should not have any rubbing issues.
Old 06-28-2006, 05:31 PM
  #555
I <3 80057's Avatar
Thumbs up
Oh ok, definately not the look I want, thanks for your help man!
Blake
Old 06-29-2006, 08:35 AM
  #556
TP121's Avatar
OK- heres one I hope someone can help me with.
Zeforged wheels: 18x9.5, 18x10.5 with the normal 275 F/295 R tire setup.
Manufacturer is telling me a BACKSPACE of 6.75" for rear, a BACKSPACE of 7.375 for front, which also gives me a 2" lip on front rim and 3" lip on back rim. I know backspace is not the same as offset- and also know there are some other variables that come into play on backspacing and offset specs.
But, are these backspacing specs right for the SS? Sounds like the wheels are gonna be tucked inside the wells, which I don't want- I want to be flush.
Can anyone give me a rough idea about these measurements?
TP121 is offline
Old 06-29-2006, 10:47 AM
  #557
Xsta Z 28's Avatar
The rough back space on my 9.5" front and 10.5" rear are:
9.5" ~ 6.7" of BS
10.5" ~ 7.2" of BS
These are only guesstimates not actual measurements. The actual offsets on both wheels is 38 mm.
Old 07-01-2006, 02:59 PM
  #558
Hambone 7's Avatar
F.Y.I., even with proper backspace for a 15" rim, Crager Street Stars will not fit around stock brakes.
Hambone 7 is offline
Old 07-04-2006, 11:28 AM
  #559
1998Z28LOADED's Avatar
Default Biggest Combo for 98 Z
I have a 1998 Z28 with the factory body kit, I have been pricing wheels but Im very picky and Im looking for the perfect fit. I have fallen in love with the new C6 corvette wheels, I was wanting 18 inch in the front and maybe 19 inch in the back. However, I dont want the rear tire height to be shorter than the front, what are the widest wheels in a 18 & 19 that will fit? Also what would be the ideal tire size combo for the 18/19 set up? If Im gonna be spending 2 grand on this I want it to be perfect.
1998Z28LOADED is offline
Old 07-11-2006, 11:34 AM
  #560
Xsta Z 28's Avatar
Post
I personally cannot stand the offset diamters on Camaros, since just as you state the side wall of the front and rear tires are different. Camaro's ABS does not like the OD of the tire to be different in excess of ~1/2" OD of the tire.
To get C6 wheels to fit "perfect" you will need to run spacers/adapters sinc the offset of the rear wheels is so large. I really do not know too much about the C6's to give proper answers.
Widest wheels . . . 9.5" is plenty up front with a 275 series tire. Out back I feel 10.5" is perfect, but a 11" can fit. Tire for out back a 295 to a 315 series fit.
Quick Reply: Wheels & Tires: Everything you should need to know is in here. A Must Read!!!!!!!
