Last edit by: IB Advertising
See related guides and technical advice from our community experts:
Browse all: Chevrolet Camaro or Pontiac Firebird Tire Repair and Maintenance
- Camaro and Firebird: Tires General Information and Specs
Step by step instructions for do-it-yourself repairs.
Wheels & Tires: Everything you should need to know is in here. A Must Read!!!!!!!
#761
ive been looking at 16x9.5" TTII and ive been searching about backspacing but i cant find the right offset for these wheels, would i need the 6" backspacing? it says the 5.5 backspacing has a +6mm offset.
#762
Assuming for the rear only . . . An no those will not fit. Offset needs to be 38 mm or higher numerically.
#764
Originally Posted by Mr. Trick
Will 18" Z06 replicas with +57 and 275/40/18's fit ok. The car is at stock ride hieght for now.
The wheels fit fine. As for the tires, I recommend the 275/35RZ18, that way the overall diamter of the tire remains unchanged vrs stock.
#766
I've been shifting through pages and couldn't find the answer to my question.
My question is; I have a 2000 Camaro, RS (ground effects, blah, blah), and would really like the C5 Z06 Rims, but I can't find any in a 17x10.5 or 17x11. I'd like to put 315s on the rear and was wondering if I'd be able to do it with an 18x10.5 rim. Would there be much BFH-ing or would I have to cut anything?
Thanks in advance!
:EDIT:
My car is at stock ride height.
Thanks in advance!
:EDIT:
#767
hey i bought a set of 4 18x8.5 BLACK Chrome C6 Motorsport Style Replica Corvette rims, didnt realise the 8.5 part till later how much will that affect my traction or will it affect it in any way?
#768
I went from 9" to 9.5" all round but kept the same size tyre - so no difference
#769
Originally Posted by sgt0704
i notice a lot of people run 275's. but would 255's work on 18x9.5" Z06 replicas with +57mm? looking to run these on all 4 corners.
thanks.
thanks.
#770
Thanks in advance!
:EDIT:
Thanks in advance!
:EDIT:
You could run 18" x 9.5" front, and the 18" x 10.5" rear. You'll need to do some minor BFH, but the wider the tire the more banging. @ 305 IMHO is the max width for a 10.5" wheel.
#771
I want to mount m/t et streets on my 15x8'' wheels should I mount 27x10.5x15 or 28x11.50x15. Looking in summit catalog they both say 8'' wheel, which doesn't make any sense to me .
#772
#773
Originally Posted by Xsta Z 28
No Z06's in the 17" diameters in the widths you ask for . . .
#774
Here's another question, since I'm a knucklehead and still don't have a confident enough grasp on this backspacing/offset business to buy some rims. I'm looking at some cheap chrome cragar 441's, mainly because I can get them in the same size as my stock wheels and use the old tires on account of me being cheap. They're 16x8's (I have the 16x8 snowflake looking wheels on a 2000 z28) and I found them with the correct bolt spacing of 4.75 inches, rear spacing listed as 4 1/2 inches. Will this fit, or am I about to do something ridiculous?
#775
#777
I got an easy question for you.... These wheels,https://ls1tech.com/forums/lsx-parts-sale/788356-z06-chrome-wheels-20-a.html. Will the bolt up to a SS or is it crucial to know you MM number on them.
I know I read the comment earlier about the biggest you'd go is 18, but its not a bad deal. Plus, just curious if they'd even work w/out breakin anything out but the lug wrench.
TIA.
Tim
TIA.
Tim
#778
I got an easy question for you.... These wheels,https://ls1tech.com/forums/showthread.php?t=788356. Will the bolt up to a SS or is it crucial to know you MM number on them.
TIA.
Tim
TIA.
Tim
The bolt pattern in the same so they will bolt up, but with out knowing the backspace of offest, I cannot tell if they fit and F-Car.
#780
Thanks Xsta Z 28
Whew, just read thru All 39 pages...and I wanted to say:
Thanks Todd for taking the time to answer all of these questions, some of which are over and over and over it seems!
You car collection is amazing too
Can wait to get my TTII's in 17x9.5 and 17x11 mounted and put on, THANKS to you!
