Last edit by: IB Advertising
See related guides and technical advice from our community experts:
Browse all: Chevrolet Camaro or Pontiac Firebird Tire Repair and Maintenance
- Camaro and Firebird: Tires General Information and Specs
Step by step instructions for do-it-yourself repairs.
Wheels & Tires: Everything you should need to know is in here. A Must Read!!!!!!!
#141
Originally Posted by Xsta Z 28
Take the wheels off, and see where the tire is rubbing. Do a littel more massaging. This is time consuming to get all the areas just right. Also, do you have an adjustable panhard, to recenter the rear?
![Icon Confused](https://ls1tech.com/forums/images/smilies2/icon_confused.gif)
#142
Originally Posted by Fierce-LS1
I do have an aphr, but how does one go about recentering the rear ... ie what do you have to measure ![Icon Confused](https://ls1tech.com/forums/images/smilies2/icon_confused.gif)
Back car onto a set of ramps, I prefer Rhino Ramps. Ideally a lift works the best. . .
Then take two lengths of string with a small weight on one end. The strings should be long enough so that when taped to the quarter panel, centered over the wheel, weight is just past the center cap.
The on each side of the car measure the distance from the string to the center cap, if the distances are different, adjust the panhard as required.
Tighten lock nuts and you are good to go!
#143
http://cgi.ebay.com/ebaymotors/ws/eB...category=43957
I am looking at purchasing these wheels, the ad states the front is a 57mm offset and and a 58mm rear....what will I need to do to make these staggered 18" z06 wheels look and function correctly using a 295 rear tire.....if possible, can these be fit without doing the BFH mod????please help ASAP
thanks
thanks
#144
thanks
thanks
#145
They fit, but the rear you will have to to the BFH, or get spacers and longer studs. . . .
#147
Hello everyone, I have a question. I have a 2000 Camaro Z28 at the stock height. I am going to be ordering black-machined face 35th anniversary SS rims that are 17 x9 with a 50mm offset. I am under the impression that the rims will easily fit, but there will be a "ugly" gap between the outer fender and the wheel well. If anyone can tell me what size spacer I need, or if I need a spacer and studs, what combination will give me a nice appearance...I would greatly appreciate it. I plan to run 275/40/17's in the rear and 265/40/17's upfront.
Thanks.
Thanks.
#148
so youre saying the 57mm offset in the front will look fine???? I will end up probably using the arp studs and a spacer...what size spacer would be safe and look the best with this set up?????5mm spacer?????????sorry for the DA questions
The rears, if a spacer was the route you wanted to got a 1/2" to 3/4" spacer, with longer studs needs to be run.
#149
Originally Posted by Dans2000SS
Will an American TT II , 17" x 11", with a 45.72mm offset fit the rear of my 2000 SS without any mods?
#150
Thanks.
Thanks.
#152
Thanks for the info. Do you know the size of the largest tire that will fit on these 11" rims without a problem? Something smaller than 315-35-17?
Thanks again for the help.
#153
![Question](https://ls1tech.com/forums/images/icons/icon5.gif)
Can you safely put 285/35/19's on all 4 corners of a Camaro. I calculated that the over diameter of the entire tire would only increase by 1.21 inches over the 275/40/17's that are on there now but I'm not sure if that would fit. My goal is to get bigger wheels and tires to fill in the fender wells and to actually get the car off of the ground a half inch higher...headers hit sometimes.
#154
I got a 2000 Camaro SS that is lowered with goldline springs. About a 2 inch or so drop. I want to put 18x9.5 Z06 wheels on all four corners with 275/35/18 tires. Will these work with absolutly NO modifications what so ever? Also what offset will look best? Looking for the wheel not to stick in to far or stick out past the fenders! Thanks in advance!
#155
![Exclamation](https://ls1tech.com/forums/images/icons/icon4.gif)
#156
![Arrow](https://ls1tech.com/forums/images/icons/icon2.gif)
#157
![Post](https://ls1tech.com/forums/images/icons/icon1.gif)
#158
How will a 00 TA be with 17x8s up front with +35mm offset w/245/45/17s and rear 17x9s with +38mm offset with 275/40/17s. Will this work alright? I dont want the wheels sticking out at all.
#159
