"front runner" tire size
so i got some 15x3.75 what size tire do i need to get? i know there is a "drag tire" but i want a street tire cause i will be DD'in these wheels
If you had a 15" x 5" wheel you could go with a 195/70/15, but your best selection of tires comes in a 205/65/15 size,but then you would need a 15" x 5.5" wheels.
Otherwise you stuck with a drag tire.
My Bad!
Here you go.
165/80/15 (25.4" tall) a little shorter than stock height
http://www.discounttiredirect.com/di...65&ar=80&rd=15
My Bad!
Here you go.
LS1Tech Co-Founder
I ran cheapo skinny tires for a long time, just be careful. A lot of those tires are not rated to carry the weight of a car like a 4th gen. I blew out the sidewall of one on the highway.
well thats why i went with a khumo... and not like an arizona or like a yellow bear or some off the wall brand.. i am not really gonna DD these tires but i will drive it to the track with them on there...
Here is a 165r15 tire that tore apart on the freeway at 135+mph. I was able to handle it and came out safe. The tread actually came apart and it tore up my fender and skirt. I was about 3 miles from my house and made it there. The tire still had air in it, just no tread.
I went with the MT sportsman radial up front also. It's a little tall but that helps me on roll out at the track. Like posted above you need something that will carry the weight.
Hey all- sorry to rehash an old thread, but had a quick question and found this by doing a search. I have M/T Fronts 24x4.0 and they look too small on my prostars, plus they are not street legal. I will be ordering a new set of 26s this week. I am torn between the Sportsman and the Sportsman S/R. Which is stronger/better tire?? I see there are two people using sportsmans and one using the S/R. I just want the best, strongest of the two tires. Thank you!
