does anyone have wheels like this?
I am planning to put a new set of rims on my 99 trans am ws6 with 18x9.5 with a offset of 53 and 19x11's in the rear with an offset of 73. they are vette rims, has anyone had issues with these types of rims on the f body and how do i figure which tires wouldn't make my trans am look all uneven and bad looking? any ideas or advice?
![Thumbs up](https://ls1tech.com/forums/images/icons/icon14.gif)
For example: 275/35/18 tire size, to get the sidewall height take 275 x .35 =
96.25 mm.
For the rear we'll try 315/30/19, 315 x .3 = 94.5 mm
Since 96.25 is really close to 94.5 , a difference of 1.75mm, which is close enough to not be noticable.
Ideally you want the sidewall height the same front and rear, or a little taller in the back to look good.
If it's not, keep the difference down to .125" or 3.1 mm of the front sidewall being taller then the rear tire sidewall.
To convert those numbers to inches divide them by 25.4.
Front tire:96.25mm = 3.79"
Rear tire:94.5mm = 3.72"
96.25 mm.
