Newbie Question: Rims stuck. Help!
Bought some new 315's for the TA, but I worked two hours last night trying to take off the old tires and rims. The rears seem to be locked on the car. I sprayed some liquid wrench and got underneith and kicked the hell out of them. Any advice. Rim Puller? Or your own method that will scratch my rims the least. Thanks.
I had this prob on my Envoy with 6 lug (!) wheels. Tried the above suggestions, tried raising the rear VERY high and then "dropping" the rear down several times with no luck. I was desperate so I put on 3 of the lugs loosely and drove (!) up and down my driveway including the curbing and voila!, when I lifted the rear the troublesome rim had "broken" free! BTW, no harm to studs or to aluminum rims occurred. Hope this helps!
the best way to remove them,,,,, jack up the car, remove lugs, now turn with your back to the wheel,, lift up one foot and very hard and firmly "back kick" the tire,,,, hitting it with the flat part of the bottom of your foot... I ALWAYS get the wheel off with this method,,, and never cause rim or stud damage.
When doing this at work, I usually leave one lug nut on about 4-5 threads from the end. Using a 3lb deadblow hammer, I hit the inner lip of the rim. Never have damaged any wheels. Dont hit the tire, doesnt help because the sidewall will flex and absorb the blow of the hammer, plus the ol newton's law comes into affect and the hammer comes back at you just as fast if your not careful. Also, be sure to use jack stands. Dont just use the factory jack or something. Dont need it to fall on you while ur under there hammerin away. Sometimes you might have to hit it with everything you got! Ive had some pretty stuck on wheels. Always caused by corrsoion build-up between the hub and wheels. Just be sure to take a wire brush to the hub and put some chassis grease on the hub before reinstalling.
