Those Running C5 Z06 Wheels on a 4th Gen
Old 04-18-2011, 11:55 AM
DannyG's Avatar
Default Those Running C5 Z06 Wheels on a 4th Gen
So, I'm interested in picking up a set of C5Z wheels to throw on my SS for track duty, but I'm a bit confused about their fitment on our cars. Proper wheel fitment on a 4th gen Camaro is no foreign subject to me as I've worked for Fikse Wheels for quite some time. However, for a 9.5" front, I would typically use a +38mm offset, and the C5Z front wheel is +54mm... That's about 5/8" difference inboard! Hence, I would think they'd rub. Same with the rear 10.5"s - A standard Fikse 10.5" fitment is +44mm offset (sometimes as far outboard as +38mm without issues) and the C5Z rear is +58mm. That's a little over a 1/2" inboard from the +44mm.
My initial assumption was that people just run spacers, which, if you ask me, is not an ideal arrangement, and not something I'm likely to do. However, I've seen people claim that they bolted the wheels right on with no spacers and ran them without issues. I've taken measurements of my car and I just don't see how they can work without rubbing, particularly the fronts - It just seems too close.
Anyone have any first hand experience they'd like to share on this subject?
Old 04-18-2011, 12:16 PM
24/48's Avatar
Check the "wheel and tires" sticky it explains ZO6 wheel fitment. Also those are damn heavy wheels for track duty, I know i have them.
Old 04-18-2011, 12:21 PM
DannyG's Avatar
If yours are heavy, they're reproductions. I'm referring to the real 2001 Alcoas or 02-04 Speedlines. Weights for these wheels are as follows:
19.6 lbs, front; 21.4 lbs, rear - 01 Z06 Alcoas
19.2 lbs, front; 21 lbs, rear - 02-04 Z06 Speedlines
The reproductions are a good 9-10lbs heavier, per wheel.
I'll check the sticky, thanks!
Old 04-19-2011, 11:51 AM
BandDirector Blk98ZM6's Avatar
FWIW, I'm running 18x9.5 Chrome C5 Z06 reproductions and they weigh 52 Lbs. w/275/35/18 tires that weigh 27 Lbs. (according to manufacturer), so my chrome reproductions weigh in at 25 Lbs. each...that's only about 4 Lbs. heaver than OEM C5 Z06's...
Old 04-19-2011, 12:01 PM
DannyG's Avatar
That's not terrible for a repro, especially in chrome... Where did you get them from?
Old 04-19-2011, 12:06 PM
Trunion King
bene's Avatar
Mine is 53 mm offset w/ both 9.5/10.5" width wheels. IIRC, I got mine from LMP. I don't use any spacers or did any BFH mod. No rubbing.
Old 04-19-2011, 12:46 PM
DannyG's Avatar
Can you do me a favor and post a couple of decent sized shots of your wheel fitment? It would be much appreciated.
*EDIT* Scratch that - I just found your gallery on Fquick.
What size tires are you running front and rear?
Old 04-19-2011, 12:56 PM
carlos64030's Avatar
https://ls1tech.com/forums/wheels-ti...uote-pics.html
Old 04-19-2011, 02:47 PM
LS1Tech Platinum Sponsor
OEWheelsLLC's Avatar
our chrome rears 18x10.5 weigh in at 23.5 lbs and the fronts 17x9.5 weigh in at 21.5 lbs
just an fyi :
__________________
Nelson W. OE Wheels
Customer Service Rep. & Sales
nelson@oewheels.net
Give us a call for fast service!
(866) 273 - 3651
Check out our wheels!
Old 04-19-2011, 03:05 PM
Xsta Z 28's Avatar
Danny, the fronts fit like OEM Camaro SS wheels which have a 56 mm offset . .
The rear 10.5 s do rub on the inner wheel well. A little BFH or a spacer make them work.
I use to run them before my Fikses. . .
Old 04-19-2011, 03:19 PM
DannyG's Avatar
just an fyi :
Really? I spoke with a rep at your company yesterday and was told all of your repro 17"s weighed 28lbs and 18" weighed 30lbs. If they only weigh what you say they weigh, I may consider a set for what I'm needing.
You have a PM.
Old 04-19-2011, 03:21 PM
You have a PM.
thats the shipping weights with packaging and materials inside the box etc.
i just weighed them before i replied to get an exact weight.
__________________
Nelson W. OE Wheels
nelson@oewheels.net
(866) 273 - 3651
Old 04-19-2011, 03:23 PM
Trunion King
bene's Avatar
275/35/18s on the front and 295/35/18s on the back.
Old 04-20-2011, 10:03 AM
DannyG's Avatar
Where did you buy your wheels from? OE Wheels only carries a 17" front and, while I can deal with that, I'd prefer to run 18"s all around.
Old 04-20-2011, 10:04 AM
DannyG's Avatar
Been a while! Glad to hear the Fikses are still treating you well
Old 04-23-2011, 12:28 PM
99 DUKE'Z 28's Avatar
That's what I call customer service!
Quick Reply: Those Running C5 Z06 Wheels on a 4th Gen
