Need Slicks for my stock 16's!
Hey guys im running on some stock five star wheels with the 8.5" width and i need some slicks to throw on them, i wanna keep the factory wheel for the fact that i like the "sleeper" look, so i dont want to upgrade wheels or anything. I need a slick that hooks REALLY well at the track, I would even consider radials if you have any ideas. I am looking at 450hp thru a 4k stall so i need something that wont blow the tires off. I am thinking a 10.5" or a 10" slick is all i will be able to fit in there... What about a radial? I will also need links to where to find these cuz its kind of a pain to find 16" tires... I found some on summit that are 28x10x16 Hoosiers (http://www.summitracing.com/parts/HOO-18153/) has anyone run a slick this size before?
Thanks in advance guys!
I need something that will last me a few runs too... I mean i hit the track every weekend and drive there as well as a little throughout the week. I dont want a 5k mile tire... I have fuzions for that
![Happy](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_stretch.gif)
Then you might as well scratch the slick idea if you want them to last.
MT ET streets are probably the best hooking dr; but they probably wear the fastest. I think you can get 15k miles out of a nitto DR depending on how you drive.
http://www.jegs.com/i/Mickey-Thompso...3794R/10002/-1
will these fit my wheel safely? I know they will bulge but will they blow off?
heres the 26x11.5s bro http://www.summitracing.com/parts/MTT-3793/?rtype=10
the ones you listed will fit fine lots of people run those on stock wheels. only problem with them is that there 28" tall unless you want a 28" tire.
Okay so i just looked at all my options for tires on my stockers... I decided to check out other options... While my car was at the shop a guy backed into my fender and headlight so he feels really bad and he wants to pay to get it fixed and painted. He then told me he had a pair of 15x9 draglites for $250. 11.5" tires should fit on those right? Then i shouldnt have any issues hooking up
http://www.summitracing.com/parts/MTT-3753/
It actually says that the minimum width is 8.80 and the maximum is 10.80, which really surprises me. I stand corrected.
295 Mt radials. they work but you need to run a low PSI like 14 -16 other wise they round out and you loose about 2 inches of contact with the ground.
I have had my car cutting 1.8 60s on the street and you can pull a 1.9 with ease
![](http://i216.photobucket.com/albums/cc150/tittan1500/TransAm/IMG_1505.jpg)
![](http://i216.photobucket.com/albums/cc150/tittan1500/TransAm/IMG_1514.jpg)
![](http://i216.photobucket.com/albums/cc150/tittan1500/TransAm/IMG_1516.jpg)
