Peeps with 335's on a Camaro please enter...
Old 05-31-2012, 03:43 PM
Dead Hook's Avatar
Default Peeps with 335's on a Camaro please enter...
Looking to do 18x10.5's on the rear with 335's. I have an adjustable track bar on order.
I understand that the Camaro's are a little bit more narrow compared to the 'Birds, so other than rolling the fender lip and using a BFH will these tuck under on a stock ride height 98? What offset and/or spacer would I need? Thanks.
Old 05-31-2012, 04:02 PM
SladeX's Avatar
315's barely fit for me WITH hammering at the well, at edge of everything, I doubt you could get 335's on without some hammering and serious modification.
Old 05-31-2012, 04:11 PM
JUSTINSWS6's Avatar
335's will rub and stick out of the fender well
Old 05-31-2012, 04:31 PM
99zee's Avatar
If you BFH enough to equal a mini tub, then maybe. A 10.5" wheel is small (dangerous)for that tire anyway.
I have had this picture saved for years. There was much debate about whether is was photoshoped.
Old 05-31-2012, 08:57 PM
carlos64030's Avatar
That's DEFINITELY Photoshopped.
1. That tire is waaaaaaay wider than the 345s on my car, and no one makes a street tire that wide in a 17" diameter.
2. Even with mini tubs, that wide of a tire wouldn't fit. The car would have to be back-halved or have the frame rails notched with full tubs to fit that much rubber.
Old 05-31-2012, 09:00 PM
JUSTINSWS6's Avatar
That tire is like a 370 that would have to be tubbed not mini tubbed. That is about 15 some inch of tire. Not possible
Old 05-31-2012, 09:59 PM
CO99Z28Vert's Avatar
335's will fit fine on that 10.5 rim! HOWEVER it is not recommended nor the safest but anyways here is the setup I have...
I have 335/30R18 pzero's and I had to BFH the wheel wells and roll the fender along with UMI on car adjustable Panhard.
Have had no problems with uneven edgewear or issues at high speed or hard turns and I am lowered quite a bit.
However the 315/35R17 GSD3's I had prior to these were just as wide and easier to mount on a 17x11 rim lol.
Picture of my car before with the 315/30R17's and 17x11 ZR1 rims:
And now:
Old 05-31-2012, 11:23 PM
Latch's Avatar
^ DAMN that looks sweet! Gotta love the cage with the top down, looks sick as ****!
Old 06-01-2012, 12:48 AM
whytryz28's Avatar
Something about verts with the top down and a roll bar in them, so sexy
Old 06-01-2012, 05:32 AM
99zee's Avatar
This - Very nice
Old 06-01-2012, 09:23 AM
tones2SS's Avatar
Originally Posted by CO99Z28Vert
Man, that looks killer. Love the stance too. What is your suspension set-up please. Thanks!
Old 06-01-2012, 03:35 PM
Brian2001SS's Avatar
Curious on the clearance as low as it sits. I've got my vert up higher to keep it off the ground. Do you scrape alot?
Old 06-01-2012, 08:28 PM
Thanks a lot guys.
I am lowered on Eibach pro springs, Bilstein shocks/struts. I bought the springs used so they did sag a little.
Honestly the only thing I recall scraping on is speed bumps and the tire rubs a little when taking a steep incline at an angle. I usually just avoid all speed bumps anyways even if I have to turn around and take another route lol.
Old 06-01-2012, 08:34 PM
Ellsworth's Avatar
thats such a sick camaro posted ^^ Lowered with the cage = dont **** with this!! haha
Old 06-01-2012, 09:41 PM
Dead Hook's Avatar
So.... A BFH, rolled lip and an adjustable panhard bar will work depending on which brand of tire. Pzero's should work but the KDW's I want most likely won't fit. Any others out there with big meat?
Old 06-01-2012, 09:58 PM
Ballzee's Avatar
Vert looks. Bad ***.
Old 06-01-2012, 11:11 PM
RoidedSS's Avatar
if that was my vert, the top would never be up.....ever
Old 06-02-2012, 12:07 AM
Brandon331's Avatar
I don't understand why people say its dangerous on ls1tech with a 335/30 on a 10.5 you see all these cobras running 335/35/17x10.5 and 335/30r18x10.5 what is the difference and the fitment on the wheels doesn't seem like it bulges out or anything
Old 06-02-2012, 07:03 PM
Edit: Posted in the wrong thread. DOH...
Old 06-04-2012, 10:24 PM
ls6jay's Avatar
Thinking of getting 335/35r17 hoosier drags any good?
Quick Reply: Peeps with 335's on a Camaro please enter...
