17" MT ET Streets - I do not recommend
![Thumbs down](https://ls1tech.com/forums/images/icons/icon13.gif)
Just spoke with Mike at MT regarding a tube for the 17" MT ET street and... there's no tube available that would fit this "tube-type" tire
and he said the tire should not be patched
. Mike told me if you get a flat on one of these tires even if it's a small hole...MT recommends you replace the tire
. That really sucks considering I just bought these &(*%$^&*&
The impression I got after my conversation with Mike (330-928-9092 ext. 113) was due to the rubber composit and the fact they're non-repairable...the MT ET streets are not really a street tire at all but strickly strip...
I'm glad I did not sell my Nitto's. BTW, I have one nearly new 17" MT ET street for sale...$75.
![Rolleyes](https://ls1tech.com/forums/images/smilies/LS1Tech/rolleyes.gif)
![Bomb](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_bomb.gif)
![Barf](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_barf.gif)
![MAD](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_mad.gif)
Originally Posted by Nine Ball
did you get a flat on the other one or what? How many miles on the good tire? I'd be interested in that good tire you have
Sorry but the tire has already sold...on a local board. The other tire caught a small nail...now it's trash with less than 100 miles on it.
I also already have my set, I knew they weren't really a "daily driving" street tire. That's why I'm trying to buy another set of 17x11 Torque Thrusts to mount these on. I had a set of 28x11.50x15 ET Streets on my V8 S10 and you could tell, that they weren't really designed for much street use.
Yea, they have a pretty flexible sidewall in my opinion, not so much on the 26x11.50x17 but on the 15", 16" wheel sizes, they have a pretty soft sidewall...and driving for any distance is less than comfortable...they have a lot of sway and "wobble" to them. I drove mine on the highway in KC one night and it took forever cause I really didn't like driving at like 60mph steadily on them.
Probably one of the main purposes of them is that they are DOT legal, even though I've seen people in KC get tickets for them, and at a track...you wouldn't have to run long wheel studs or a driveshaft loop like you would if you had ET Drags.
I'm a big fan of ET Streets, I think they are a great tire for racing on the street...I'm anxious to see what the 26x11.50x17s will do for me.
Best way to go with these tires is mount on seperate rims and haul to track (IMO).
LS1Tech Co-Founder
ET Streets are definitely not daily-driver tires. If you ever have been caught in the lightest of rain showers on ET Streets, you are limited to about 20 mph otherwise you will slip right off the road. They SUCK when the road is damp, I had to drive 20 mph on the shoulder of the freeway once, any faster and the car got sideways.
But, they are a good all-around raceday tire that you can drive to the track with, as long as you don't hit water or nails
![Winky](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_wink.gif)
Nittos are probably the best streetable drag tires available. BFG DRs are better strip tires but worse street tires (much worse rain peformance, and higher wear rate). The new MT DRs are probably even more towards the strip extreme, but still streetable. ET Streets are just street legal drag tires, a small step down from true ET Drags (which are not street legal).
Dope
