drag wheels for 4th gen
Weld RT-S Don't need to touch a thing.
The rear are 15x10 7.5 BS and the fronts are 15x7 4.5 BS both are "medium pad".
Back tires are Nitto 555R 275/50/15
Front tires are Goodyear Eagle GT 225/65/15
![](http://img.photobucket.com/albums/v439/SongasRacing/Pauls%20Camaro/P1011404.jpg)
![](http://img.photobucket.com/albums/v439/SongasRacing/Pauls%20Camaro/pstire.jpg)
![](http://img.photobucket.com/albums/v439/SongasRacing/Pauls%20Camaro/P1011407.jpg)
I'd like to run a 15 x 5 medium pad wheel with 3.5" BS with 98-02 front brakes, which should clear if your wheels clear like you say they do, and also tuck in nicely like a stock wheel. I don't like wheels/tires that stick outside of the top of the fender AT ALL; it looks
![Mullet](https://ls1tech.com/forums/images/smilies/mullet.gif)
Let me get this straight. You fit a 15" wheel with a 4.5" BS on the front of your car without ANY grinding/spacers? What kind of brake setup do you have?
I'd like to run a 15 x 5 medium pad wheel with 3.5" BS with 98-02 front brakes, which should clear if your wheels clear like you say they do, and also tuck in nicely like a stock wheel. I don't like wheels/tires that stick outside of the top of the fender AT ALL; it looks![Mullet](https://ls1tech.com/forums/images/smilies/mullet.gif)
Keep in mind his LT1 front brakes are smaller than LS1 brakes. Not saying they wouldn't fit on a LS1 front setup because I have no experience with anything larger than 4.5 width on the front.
